Old 25th December 2009, 17:27   #1
lobojames9's Avatar
Thanked: 13 Times
Default Clutch is very hard
Hi guys,
I guess this will be a bit of a noob question. But i am one as far as cars are concerned. Just recently did i start driving. Mostly ride my bike. Anyways, The clutch on my sister's M800 seems to be very hard. Even she complains of the same. I know its not an apt comparison, but compared to the Spark that my dad owns the clutch on the M800 is very hard and strains the leg muscles. Is there a reason why it is so hard? How do i make it softer?
The car is a 2002 model M800.
Thank you in advance for your help.
lobojames9 is offline   Reply With Quote
Old 25th December 2009, 17:30   #2
kingofmyworld's Avatar
Thanked: 248 Times
Clutch plates got worn out i believe, I think they are due for a placement, Get them replaced and it'll be smooth again.
kingofmyworld is offline   Reply With Quote
Old 25th December 2009, 17:38   #3
lobojames9's Avatar
Thanked: 13 Times
You have a lovely M800 kingofmyworld. I am going to be the future owner of the 800, that is after my sister gives it to me. So just looking into all these things so that i have the car like i want it when the keys come to my hand.
How much do the clutch plates cost?
Old 25th December 2009, 17:46   #4
Thanked: 248 Times
Thanks mate
If your m800 is a 5speed one then you need to get alto clutchplates for it. It'll cost you around 3k + or - 500 including installation charges and taxes.
Old 25th December 2009, 18:47   #5
IndigoXLGrandDi's Avatar
Thanked: 160 Times
If I am correct, M800 has Dry Clutch. Hence the clutch gets Hard with usage.
I dont think there is compulsion of changing the clutch plate assembly as a whole.
You can go for replacement of clutch plate only since the springs of Clutch Disc get tighten by usage. Dont change other parts if not needed.
IndigoXLGrandDi is offline   Reply With Quote
Old 25th December 2009, 18:50   #6
Thanked: 248 Times
Consult your service adviosr as well as a local mechanic and do the needful.
Old 25th December 2009, 18:58   #7
Hashim's Avatar
Thanked: 32 Times
First try lubricating the clutch cable with engine oil and pedal lever joints by grease, if its still hard change the cable. If nothing works then changing the clutch plate (and pressure plate if its damaged too) is the final option.
Hashim is offline   (1) Thanks Reply With Quote
Old 25th December 2009, 19:51   #8
lobojames9's Avatar
Thanked: 13 Times
Thanks for the advice guys. I shall try lubricating the clutch cable as my sister said that she had changed the clutch plates not more than a year back.
@kingofmyworld: It is a 4 speed 800.
@all: If i am allowed to take the topic a little OT, i have one more question: What is a good tire and tire size for the M800. The car needs a tire change too. I am looking for a good VFM tire. Do tires have to be changed all at once?Or can it be done in pairs?
All help is greatly appreciated.
Old 26th December 2009, 00:18   #9
Thanked: 658 Times
change the cables. its just rs.120/- instead of lubricating. and do the settings according to your need.
Old 26th December 2009, 10:07   #10
lobojames9's Avatar
Thanked: 13 Times
Oh if its only that much. Then surely will change the cables.
Old 26th December 2009, 10:26   #11
If the clutch is not worn out and has been changed a year back, then there is no need to change the clutch. A hard clutch does not indicate a worn clutch.
First it is the moving parts like clutch pedal, cable and joints need to be checked.
If these are ok then the internal needs to checked.
Mostly, the cable is the cause.
rkguru is offline   Reply With Quote
Old 26th December 2009, 14:08   #12
Hashim's Avatar
Thanked: 32 Times
Open your driver side door and you should see a label somewhere near the door lock hook on the chassis indicating OEM tire size or else look in manual I think its 135/70 R12 ??, stick to that for good fuel efficiency. JK tyres are more VFM than other brands IMO. You can change only a pair (both front or both rear) if you want.
Hashim is offline   Reply With Quote
Old 26th December 2009, 14:54   #13
lobojames9's Avatar
Thanked: 13 Times
Thank you Hashim and rkguru for your replies
Old 26th December 2009, 16:42   #14
Thanked: 248 Times
Stock size is 145/70 R12.
Old 27th December 2009, 10:59   #15
mithun's Avatar
Thanked: 49 Times
Originally Posted by lobojames9 View Post
Hi guys,
First of all don't compare the clutch of Spark & M800, Spark's would always be softer.
How much KMS have you done ?
Check the cabling or do the adjustment before going for any major repairs.
Esteem steering getting very hard in the afternoon atulrastogi Technical Stuff 10 26th August 2006 20:52
A very very very hot Murcielago. v12 The International Automotive Scene 18 14th July 2004 22:04
