Old 26th December 2009, 00:00   #1
Thanked: 89 Times
Default Baleno(altura) skidding a lot
My car has done almost a lakh km, about 500km away; It's in excellent condition otherwise but off late the braking's become scary. It goes into a skid even under relatively light braking. Tap the pedal hard and it's certainly going t skid.
I've driven and owned other Non abs vehicles 2 but it's never as bad as in my case. It's happening 3-4 times a day, Like a said A slight hard tap and you're greeted with screeching tyres. Please help,ask for more details if you need to know anything . I've stopped taking my car t MASS, take it t a local but very competent mechanic, thought I'd take an opinion here as well.
1- New tyres
2- Front gas shocks, new
3- Front brake bads changed a few months back(original, whatever suzuki provides)
sukrit7 is offline   Reply With Quote
Old 26th December 2009, 00:15   #2
Thanked: 658 Times
tyres are ruled out as you have new tyres.
check the following.
easiest solution
1. check the alignment.
2. when did you last flushed the brake oil
more karchila type.
3. front rotor. not in shape, developed groves.
4. rear pads sticking and locking, when did you do the rear wheel servicing
5. slave cylinders sticky.
Old 26th December 2009, 00:26   #3
binz's Avatar
Thanked: 411 Times
Have you checked tyre pressures?
Old 26th December 2009, 00:56   #4
pranavt's Avatar
Thanked: 272 Times
Is it actually skidding (locking tyres) or just making a screeching noise? The noise could be attributed to the tyres. Which tyres are you using?
Old 27th December 2009, 16:33   #5
I dont know how far the issue is related to yours, but I had a similiar problem with my tata sierra turbo. Got it rectified by balancing and aligning all the four tyres.
rgds
hlk
hulkonline is offline   Reply With Quote
Old 27th December 2009, 20:01   #6
Jaggu's Avatar
Thanked: 7,470 Times
If its just screeching tires check the alignment, misaligned wheels can make weird sounds while cornering and braking.
Otherwise good idea to do a complete brake overhaul and see if it helps.
Jaggu is online now   (1) Thanks Reply With Quote
120 and more skidding incidents in 2 days dkhatau Street Experiences 4 10th June 2008 22:10
Honda discusses skidding issue with NHC VTEC sathya_nars The Indian Car Scene 75 20th October 2007 06:21
Baleno / Altura 2002 model, pls suggest naveendhyani Sedans 0 27th February 2006 10:56
price for 2002 baleno altura adityapd The Indian Car Scene 3 30th January 2006 09:48
Wanted a used Baleno Altura adityapd Shifting gears 5 27th July 2005 14:10
