Old 26th December 2009, 12:59   #1
Question Maruti Baleno engine light glows?
Hi T-BHP,
I have been driving a Maruti baleno vxi from last 3+ years with no issue what so ever with it, but just today morning i faced a strange problem. Once i plugged the key it showed all the indication on the dashboard but after starting my car the Engine light(orange) did not go off.
I waited to see if it might go i some time, but it never did.
I switched off and started the car again 2-3 time but the same. Thinking it might be major issue i parked my car back in garage (as I didnt have time to go to a service center) & took my M800 instead.
What i want to know is that is it safe to drive the car in same condition to a MASS or should i call the MASS guys down.
One more thing i also checked the engine oil level in the car and found it at proper level. Also the car had been serviced in november as per the schedule.
Please help guys.
hulkonline is offline   Reply With Quote
Old 26th December 2009, 16:16   #2
Thanked: 103,675 Times
Most probably, your CMP / O2 sensor has gone kaput. No big deal, just have the authorised service station diagnose & replace. Cost = About 2,000 odd rupees
BTW, good call in parking her back and using the other car. Never drive with the check engine light glowing.
'99 Baleno check engine light on (1999 Baleno - Check Engine Light)
Another Baleno owner's experience with the engine light (Baleno - Emission Malfunction Light Glowing)
Old 26th December 2009, 16:21   #3
v&v
v&v's Avatar
Thanked: 1,099 Times
Originally Posted by hulkonline View Post
Hi T-BHP,
Please help guys.
I too had the same problem. it was overhead cam sensor error. you can get the error code generated. They charged 2.2 k for it.
v&v is offline   Reply With Quote
Old 26th December 2009, 18:17   #4
Thanks GTO and V&V for responding early.
I have 2 more query
1) where exactly is the O2 sensor located approx?
2) Today when i was observering the Engine light glow i found a strange thing i.e. when my vehicle is in neutral and steady position with engine running steering towards right or left the tacho shows a rise and then falls back to normal (800rpm if not wrong). is this normal in all cars.
rgds
hlk
Old 26th December 2009, 21:36   #5
bj96's Avatar
Thanked: 130 Times
...when my vehicle is in neutral and steady position with engine running steering towards right or left the tacho shows a rise and then falls back to normal...
Not sure, guessing that Baleno has a hydraulic power steering driven off the engine. When you turn the steering either way, it puts a momentary load, making the motor spin faster to catch up with the load. You will notice similar thing (rpm increase) if you put a sudden load e.g. switch on AC compressor or even headlights. Should be normal- if, the flip in the rpm is not very high.
-BJ
bj96 is offline   Reply With Quote
Old 27th December 2009, 07:44   #6
v&v
v&v's Avatar
I have 2 more query
rgds
hlk
This is normal. it happens in mine baleno too. BJ96 is spot on. Load on engine is making the rpm to fluctuate.
Old 27th December 2009, 09:49   #7
amith.2974's Avatar
+1 to BJ96, it happens on mine as well as other balenos. Funny you havnt noticed it till date.
amith.2974 is offline   Reply With Quote
Old 27th December 2009, 11:49   #8
shuvc's Avatar
Thanked: 287 Times
Is most probably the O2 sensor. I faced this while out driving in the city. Called up MASS, they asked me the symptoms, and then said it's ok to drive the car to the workshop - a distance of about 5kms. The sensor was changed. No issues since then. This was almost 1.5 yrs ago.
And hydraulic power steering has that effect on the rpm.
Old 25th October 2010, 09:06   #9
akas_chauhan's Avatar
Thanked: 22 Times
I have a power steering issue in my Baleno.
I had accident a year before, repaired car. HOwever there was power steering issue , while turning steerling it was making noises. MASS wrongly diagnosed it a power steering Pump issue, ordered Pump and replaced it. Issue persists, then they found dust in Power steering pipes, they said they flushed it gave me the car.
I drove car, found issue gone.
But after couple of months issue reappeared slowly and recently power steering Gave up. Oil leaked and MASS said Power steering Assembly needs to be replaced, which costs 55K approx.
When i asked them why the flushing did not clear all the dust, they said flushing can not clear al dust. What ever best they could do, they have done. Is this statement by MAAS correct?
I still have extended warranty and am following up with MASS since last 2 weeks if it can be replaced within extended warranty. However chance is gleam as they said it's due to impact of accident and power steering rack was replaced during the accident repair. Maruti had asked them history and MASS provided history mentioning "Power Steering Rack" repaced during repair work.
I would need advice in terms how to proceed in this case. I feel MASS could not properly diagnose the problem, which if identified in early stage should not have caused a power steering assembly to fail.
akas_chauhan is offline   Reply With Quote
Old 20th November 2010, 00:55   #10
MileCruncher's Avatar
Thanked: 357 Times
Just two questions:
  1. Was the car repaired at the MASS for accident
  2. If it was why did they not check it ?
Just tell them that if they didn't check it then, that's their problem. You had reposed your full faith on them to get the car repaired and you can't be blamed for their incompetence.Tell them that you had the chance then to get it changed under insurance and since they hadn't done it then, they should do it now under warranty. These are general fobbing off techniques and you shouldn't buy it.
I suggest you escalate the matters further within Maruti. I see a genuine case of ASC incompetence and they trying to milk the customer accordingly as it might not pass the warranty test and the ASC might have to foot the bill.
MileCruncher is offline   Reply With Quote
Old 20th November 2010, 02:01   #11
Thanked: 357 Times
Just two questions:
Old 24th November 2010, 19:53   #12
Thanked: 22 Times
Originally Posted by MileCruncher View Post
Just two questions:
Yes it was repaired at MASS. Now they are saying since after accident car was not towed instead we drove the car thats why It'll void warranty. I asked them where it's documented, they never gave any answer. I know they are playing pranks. I'm waiting since last 1 month for this warranty thing and fed up with these guys.
Not sure which one is Maruti compaint official website. Not much hope but i'll complain.
However i'm now eager to solve this issue and looking for good mechanic in bangalore who can give reasons why it's gone bad, what part is issue etc.
Thanks for your reply again Milecruncher.
Old 25th November 2010, 07:49   #13
Thanked: 357 Times
Thats load of bull. The ASC is supposed to fix the car from what you brought to them.
I suggest to speak to the local Service Head. You can find the details of the local MUL office from Justdial
All the best in getting this sorted.
Don't give up.
Old 25th November 2010, 12:31   #14
deutscheafrikar's Avatar
Thanked: 324 Times
Is the poweresteering rack leaking the oil from it's seals?
deutscheafrikar is offline   Reply With Quote
Old 25th November 2010, 18:47   #15
Thanked: 22 Times
Today i took car to Fastcars in bannerghatta Road. They said they will open the Rack and fix it. Seems like you are right, its leaking from its seals.
MIL Light glows while running on CNG in Honda city rajeevpatel Technical Stuff 15 29th August 2012 20:55
1999 Baleno - Check Engine Light ecurb_jm Technical Stuff 7 22nd December 2011 11:51
Oil check light glows in 118NE, AFTER removing key adhiraj Technical Stuff 4 31st August 2010 21:39
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
Pedrossa shines but Rossi glows at Donington Park! turbo_v12 Int'l Motorsport 7 5th July 2006 11:11
