Old 28th December 2009, 15:52   #1
fast_elegance's Avatar
Thanked: 89 Times
Exclamation Best engine rebuilders?
Hi all,
I have a Fiat Siena 1.7 Turbo Diesel. Its done close to 1.2L
As i am so attached with the car and i love driving it, i wanted to keep it. But there are some issues with engine such as inlet valve leak or something. So, i wanted to do a good engine over haul.
Is it possible to buy a brand new Fiat engine which fits fo example: Fiat Palios or something like that may be Swift DDiS (which is essentially a Fiat engine)? If yes, where can i buy them and how much will it cost? Any technical/ compatibiltiy issues?
Please suggest some expert engine rebuilders who has knowledge and are tustworthy in Bnaglore and Kerala area.
Thanks for your help
fast_elegance is offline   Reply With Quote
Old 28th December 2009, 16:02   #2
wildchild4lyfe's Avatar
you could try psycho if you are looking for a completely different engine..
wildchild4lyfe is offline   Reply With Quote
Old 28th December 2009, 16:15   #3
nitrous's Avatar
Thanked: 285 Times
If your compression is good, just fix the valve leak and go on.
Rebuilding an engine will need a ton of new engine parts and I'm not so confident about the 1.7 TD engine's spares availability.
Old 29th December 2009, 21:01   #4
Thanked: 33 Times
As someone recommended here, better get the valve leakage fixed and continue using the car. You haven't specified any problems that may lead someone to determine that perhaps your car is reaching the engine O/H stage. And even if your car may require and engine O/H in future, its such a hassle to accumulate all the parts required for an engine O/H especially for cars that are not common on indian roads.
ritedhawan is offline   Reply With Quote
Old 5th January 2010, 09:51   #5
Psycho's Avatar
Thanked: 95 Times
If you feel that the power may have dropped please check the compression it could help you identify if you need new rings along with the valve job.
Swapping engines when you are ok with the current one would not make sense.
Old 5th January 2010, 13:59   #6
quattroa4's Avatar
Thanked: 143 Times
repairing it seems to be a viable option ! should run for another 60 or 70k comfortably. i will suggest to do a dynamo test to chk all the parameters concerning your engine
quattroa4 is offline   Reply With Quote
Old 5th January 2010, 14:22   #7
Psycho's Avatar
Thanked: 95 Times
Can you please explain
Old 5th January 2010, 17:13   #8
hey whats a dynamo test?
do you mean a scan or a dyno test?
a dyno test wouldnt make any sense though...
Old 7th January 2010, 15:57   #9
Thanked: 89 Times
whats this "psycho"? a shop? sorry for my ignorance!
All, please suggest me some good engine repair shops in bangalore/kerala
Old 8th January 2010, 13:09   #10
Thanked: 103,359 Times
Best for you to have a diesel engine specialist give the once over to your 1.7 TD unit. Also, since the car has covered substantial mileage, your turbo could need an overhaul too.
I think you meant dyno test? Either ways, a compression check is a far better / viable option.
BHPian "Psycho".
Please search through the forum.
Old 13th May 2018, 19:04   #11
Default Re: Best engine rebuilders?
I am also looking for an ENGINE SPECIALIST in Bangalore but not able to findout in the threads. If anyone know any such Engine Specialist, please share contact details.
ravichopra is offline   Reply With Quote
Best Global Brands and Best Automotive Brands vasudeva The International Automotive Scene 4 9th October 2015 09:21
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
Best of Everything... Which tire is the Best..??? rana_kirti Tyre & Alloy wheel Section 93 21st May 2007 23:20
The best of the best! Revvmaster The International Automotive Scene 19 27th July 2004 22:59
