Old 14th April 2010, 17:42   #16
ghpk's Avatar
Thanked: 193 Times
I think new one is 400+ but i got it done with some jugaar so didn't purchased it.
Old 25th November 2014, 11:00   #17
batterylow's Avatar
Thanked: 711 Times
Default Low beams not functioning
Dear Team,
I drive a less than 3 year old, 60K kilometer run Ford Figo.
It has a HID kid (H4) running on the stock reflectors since the stock headlights were not sufficient for my driving. All was ok for a few months but now problems have cropped up.
Problem number 1:
The headlight flasher stalk got stuck in the high-beam position. The guy in the accessories shop where I installed the kit suspected that the wiring for the kit has gone bad and so we got the wiring re-installed. The problem persisted so he suggested that the headlight flasher switch is kaput. This was confirmed as the indicator on the console was also stuck in the high beam position.
At this point when we disconnected the hid kit and installed a normal H4 bulb and both the filaments were glowing.
The relays were working fine and we swapped the relays still the result was the same. So the headlight flasher switch was changed. Moving on to problem number 2.
Problem number 2:
The head light flasher switch was replaced and now the light in the console is alternating properly and we can hear the relay getting actuated. However the low beam refuses to glow and the same was confirmed with a normal bulb. Power supply seems to be fine up-to the relay and then there seems to be no supply to the low-beam.
What could be problem here? The HID kit seems to not be the culprit as the low-beam does not work even with the kid disconnected.
Power supply is available up-to the fuse-box.
Any pointers would be helpful.
Thank you.
BL
tl;dr:
No power to low beams, low beam relay is getting actuated but no supply beyond that. High beams are working fine.
@Mods
Searching the forum leads to topics with only the bulbs or the relay kaput, hence the new thread
batterylow is offline   Reply With Quote
Old 25th November 2014, 12:39   #18
sudev's Avatar
Thanked: 2,666 Times
Default Re: Low beams not functioning
lowbattery and head (low beam) light not working......sure is this is coincidence?? !!
Check earth wiring also.
sudev is offline   Reply With Quote
Old 25th November 2014, 13:51   #19
batterylow's Avatar
Thanked: 711 Times
But that would make even the high beam faulty right?
Or am I missing something?
Old 29th November 2014, 16:00   #20
batterylow's Avatar
Thanked: 711 Times
Default Re: Low Beam not working
Problem solved!
The issue was with the new headlamp flasher switch which turned out defective.
Another new switch was used and all is Ok!
Radiator fan - Low speed not working MadRash Technical Stuff 7 2nd April 2014 13:50
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
Pulsar 220 F 2010 - Low beam leveling issue kingofmyworld Motorbikes 13 31st August 2010 00:16
How To : Tell the oncoming vehicle to use low beam headlight!! racingmachine Street Experiences 62 9th December 2009 22:56
Short throw in low beam Samurai Technical Stuff 17 7th October 2008 01:39
