Old 27th January 2010, 12:13   #46
planet_rocker's Avatar
Thanked: 368 Times
DIN chak...
Today my palio's battery went kaput. called the BatMobile Service and they diagnosed the battery needs replacement.
Gravity in 6 cells - 11 / 12.1 / 12 / 12 / 12 / 12.
Charge - 14.4 without load.
When i checked the manual - it says 50ah specification for the battery. i have ordered for a DIN50 with Exide - will that be a problem?
is the battery specification different in the Palio Vs the Adventure - 50ah Vs 55ah?
Palio Battery options DIN50/DIN55 and manufacturers-photo0234.jpg
Palio Battery options DIN50/DIN55 and manufacturers-photo0233.jpg
Palio Battery options DIN50/DIN55 and manufacturers-photo0235.jpg
planet_rocker is offline   Reply With Quote
Old 27th January 2010, 22:03   #47
Thanked: 368 Times
bought Exide DIN50 Battery
price - 5300 INR
Old 28th January 2010, 11:18   #48
lohithrao's Avatar
Thanked: 163 Times
P_R, not sure what adverse effect will be there if one goes for Din55?
anyhow i feel 5300is bit higher price you paid, i got the 55Din Exide for 5400 after exchanging the old battery.
lohithrao is offline   Reply With Quote
Old 28th January 2010, 11:54   #49
Thanked: 368 Times
Could be. DIN55 costs a bit more than DIN50 in Kolkata (MRP). I got it at a discounted rate. Dealer Delivered & fitted the battery at my place. I didn't go and pick it up from the dealer.
I got 650/- for the old battery.
DIN55 provides starting amps longer than DIN50 / more capacity - will be able to provide more current for the same period (if you need it) / as long as voltage (12V) remains same and battery fits in the bay both should be OK
Old 28th January 2010, 12:06   #50
lohithrao's Avatar
Thanked: 163 Times
Same here, i had to just call the dealer. he delivered the batt to my place.
btw 5300 is after deducting 650 bucks(old batt cost) or before deducting?
Old 28th January 2010, 12:55   #51
Thanked: 368 Times
5300/- after deducting 650/-
What was the dealer quoting for the DIN55 before bargaining? how much did you get for the old battery?
i think the thread title needs to be changed
Palio Battery Options - DIN50 / DIN55 / DIN60 - Brand, Price and Options
Old 28th January 2010, 13:05   #52
lohithrao's Avatar
Thanked: 163 Times
I think he was quoting 6K for the batt
btw did Harsha and Khanbhai purchase the battery? the price quoted by the dealer was very good.
Old 28th January 2010, 14:22   #53
Thanked: 368 Times
Same here - dealer quoted 6K + (MRP)
Related Link to Exide Bat Mobile Service: http://www.team-bhp.com/forum/access...d-service.html
Old 24th April 2010, 13:14   #54
bottle's Avatar
Thanked: 138 Times
I had to replace the battery on my car and went in for DIN55. It sticks out slightly out of the tray on the side but the connections and all fit ok. OTher than that are there any adverse effects to fitting a higher output battery ?
bottle is offline   Reply With Quote
Old 24th April 2010, 13:55   #55
Thanked: 85 Times
Originally Posted by deutscheafrikar View Post
Lolithrao
I am using a BOSCH SR-60R in my indigo marina diesel.
Bosch Batteries are rebadged Amarons.
Another good option is TATA Green.
Live To Jive is offline   Reply With Quote
Old 24th April 2010, 16:01   #56
bottle's Avatar
Thanked: 138 Times
Here is a picture of the battery installed
Palio Battery options DIN50/DIN55 and manufacturers-dscn1730.jpg
Old 27th August 2010, 17:05   #57
sivathetechwiz's Avatar
Post Amaron FLO, DIN45 at Chennai for Rs.5480.
My 2003 Palio ELX wouldn't crank up suddenly one day - its Amco DIN44 battery has passed away. The neighbourhood battery service guy confirmed its death, declaring "The main cell has died. You have no option but to replace the battery."
Seeing most people swearing by Amaron's reliability, I decided to give it a try. Headed to the nearest Amaron PitStop and hit upon a situation - They stocked only DIN45 and DIN55. But not DIN50 which I wanted (since it was the OEM as many people in this forum had said). He said the usual story, his manual suggests DIN45 for Palio, blah blah. I struck upon a deal whereby I could take home both a DIN45 and DIN55 so that I could fit DIN55 if possible, else settle with DIN45. To my disappointment, by car's battery bay could not hold a DIN55. So settled for the DIN45. He quoted a price of Rs.5480 for it, while he would take also buy my old battery for Rs.400.
Name:  Image0325 Small.jpg
At the end of the day, I purchased an Amaron FLO, DIN45 Battery with 48 Months warranty (the usual pro-rata after 24 months) for Rs.5000 at Chennai, in exchange for my old Amco DIN44.
sivathetechwiz is offline   Reply With Quote
Old 26th July 2011, 11:57   #58
praful's Avatar
Thanked: 442 Times
Default Re: Palio Battery options DIN50/DIN55 and manufacturers
Bringing back a old thread!
My car was unused for a while and now the car starts only with dhakka start! The battery is OEM 6+ years old. I don't want to be stuck in traffic and do a dhakka start again.
For the 1.2NV Sport what is recommended DIN45/50/55? I am running upgraded lights and a slightly powerful ICE setup.
OEM was Amaron and I am kindda leaning towards Amaron again.
Any recommendations for models/dealers here in BLR?
praful is offline   Reply With Quote
Old 26th July 2011, 12:09   #59
lohithrao's Avatar
Thanked: 163 Times
Praful give a shot to base terminal, their price is great! though not sure how much it is...
btw i think its Din50
Old 26th July 2011, 12:15   #60
Thanked: 368 Times
I am running DIN50 in my GTX, Bottle is running DIN55 in his 1.6 Stile` - DIN55 Exide may require a small modification of the battery base (not that important if secured right).
DIN55 is the best bet. Manual suggest DIN50
Palio Battery options DIN50/DIN55 and manufacturers-batt.jpg
Cruisers in India - Do we need more options from manufacturers ? TaurusAl Motorbikes 26 20th January 2012 13:53
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Strike affects battery supplies to motorcycle manufacturers! anjan_c2007 Motorbikes 3 4th July 2010 17:16
Help on Shifting from DIN50 to DIN55 and Which Brand? gemithomas Technical Stuff 2 10th June 2009 13:33
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
