Old 26th July 2011, 12:17   #61
lohithrao's Avatar
Thanked: 163 Times
Default Re: Palio Battery options DIN50/DIN55 and manufacturers
Even i have Din55 on my car, so far so good
Originally Posted by planet_rocker View Post
I am running DIN50 in my GTX, Bottle is running DIN55 in his 1.6 Stile` - DIN55 Exide may require a small modification of the battery base (not that important if secured right).
DIN55 is the best bet. Manual suggest DIN50
Attachment 583155
lohithrao is offline   (1) Thanks Reply With Quote
Old 26th July 2011, 12:23   #62
planet_rocker's Avatar
Thanked: 368 Times
I have tried to keep the car as Stock as possible - yup! DIN55 is the best option.
planet_rocker is offline   Reply With Quote
Old 26th July 2011, 12:35   #63
praful's Avatar
Thanked: 442 Times
Originally Posted by lohithrao View Post
Praful give a shot to base terminal, their price is great! though not sure how much it is...
btw i think its Din50
Attachment 583155
Any specific models of Amaron for DIN55?
praful is offline   Reply With Quote
Old 26th July 2011, 12:45   #64
Thanked: 368 Times
Don't have a flash player in my office PC - try out this link www.amaron.in
happy hunting
Old 26th July 2011, 12:56   #65
praful's Avatar
Thanked: 442 Times
happy hunting
Have seen that website already. But they don't list out batteries based on DIN!
Old 26th July 2011, 13:12   #66
Thanked: 368 Times
Grrrr - check out batteries with 55 / 50 Ah ratings, if provided
Old 26th July 2011, 13:56   #67
praful's Avatar
Thanked: 442 Times
Their website doesn't list any tech specs or if it does, I've gone blind
Old 26th July 2011, 14:36   #68
Thanked: 368 Times
Praful Bhaina, just call up a dealer and ask them if they have a DIN55/50 equivalent and ask for a quote and exchange rate for the old battery.
Don't overdo the "dhakka start" - take care of the catcon - IIRC it costs around 15k for the palio
Old 26th July 2011, 19:25   #69
praful's Avatar
Thanked: 442 Times
Ok, got a quote and some news.
Manufacturer reccomends DIN50, Amaron recommends DIN45!
Quotes I got :-
DIN55 - 6.6K
DIN45 - 5.75K
500 bux for the old battery and 100 bux for home delivery, the currenty battery is totally drained!
Old 26th July 2011, 21:46   #70
Thanked: 70 Times
Am using a DIN60 Tata Green in my Fiat Petra 1.6
Purchased it for Rs. 5000 in Oct. 2010. No issues so far
rikhav is offline   Reply With Quote
Old 26th July 2011, 21:50   #71
R2D2's Avatar
Thanked: 2,031 Times
Quotes I got :-
DIN55 - 6.6K
DIN45 - 5.75K
Amaron does not make a DIN50/55 which is why they recommend a DIN45. My dad got his car (a 1.6 Palio) fitted with a DIN55. Go in for the 50 if you are not keen on the 55.
Old 27th July 2011, 10:27   #72
praful's Avatar
Thanked: 442 Times
Got a quote of 5250 [Battery] - 500 [Old Batt] = 4750 from BASE Terminal batteries for DIN55. With free home delivery.
Now I intend on letting go of this car in 1-1.5 years time, should I opt for BASE instead as its cheaper?
Not push starting the car as current battery is completely dead. How are the reviews for BASE?
praful is offline   (1) Thanks Reply With Quote
Old 27th July 2011, 12:34   #73
Thanked: 368 Times
go for it - a new battery will last that long for sure, i mean 1-1.5 years.
How many kms did the car clock? 12,000kms by you + ___?
Old 27th July 2011, 13:35   #74
praful's Avatar
Thanked: 442 Times
Car is now 33K kms old, its a April'2005 model
Have decided to go for the BASE DIN55 battery
Old 27th July 2011, 17:22   #75
Thanked: 70 Times
My cousin installed the same battery for his swift diesel. No issues since 2 years
Ironically, since I posted yesterday about my cars battery (TATA GREEN), I am having some starting problems. Not sure if its battery related or something else
rikhav is offline   (2) Thanks Reply With Quote
Cruisers in India - Do we need more options from manufacturers ? TaurusAl Motorbikes 26 20th January 2012 13:53
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Strike affects battery supplies to motorcycle manufacturers! anjan_c2007 Motorbikes 3 4th July 2010 17:16
Help on Shifting from DIN50 to DIN55 and Which Brand? gemithomas Technical Stuff 2 10th June 2009 13:33
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
