Old 22nd July 2014, 01:01   #91
Thanked: 544 Times
Default Re: Palio Battery options DIN50/DIN55 and manufacturers
Originally Posted by Shutterbugger View Post
Battery for my Fial Palio 1.2 Petrol has conked off and need to change it. Can someone tell me what would be the right amps battery to use and if there is a brand that is better suited to Palio? Also what does "DIN" in terms of a battery mean?
Thanks a ton!!
Originally Posted by chakri400 View Post
.... I called multiple dealers and everyone said I need to pick din45 from amaron (that includes amaron helpline). I think suggestions on this thread seem to indicate din50/55. Did I get the wrong battery!
Originally Posted by lucifer919 View Post
My 1.6 came with a factory fitted Exide DIN 50 battery so that's what i replaced it with. Incidentally, Amaron does not make a DIN 50 battery so i had to buy an Exide (which is more expensive)
Having owned a Palio 1.2 for 12+ years, I can confirm that the factory specification for Palio 1.2 Petrol is DIN 50 (not DIN 45 and not DIN 55)
DIN is simply the Ampere Hour (AH) electical capacity of the battery. Please go for DIN 50 (stands for 50 AH) for Palio 1.2
Exide Matrix comes with DIN 50 rating, I last bought it a couple of years back through Batterybhai.com
The first battery (Exide DIN-50) lasted about 3 years
The second battery (Exide Freedom DIN 55) was going strong even after 7.5 years I replaced it just as a preventive measure with a new battery, didn't want to get stranded unexpected and wait any longer.
I wouldn't recommend a DIN-55 based on personal experience of frequent blown fuses. (In theory DIN-55 is no harm as it is just a higher capacity battery)
Third time around and wiser, I stuck to original specification and went for Exide Matrix DIN-50
for_cars1 is online now   (2) Thanks Reply With Quote
Old 22nd July 2014, 01:14   #92
SunnyBoi's Avatar
Thanked: 2,767 Times
Just checked the owners manual and it stated car needs a 50Ah battery, which translates into DIN50. My car's been running fine with a DIN45 though, I'll let it run as long as it runs. I stand corrected though
SunnyBoi is offline   Reply With Quote
Old 22nd July 2014, 22:26   #93
chakri400's Avatar
Thanked: 99 Times
Every dealer I spoke to suggested exide din50 or amaron din45 as if the two are equivalent!
chakri400 is offline   Reply With Quote
Old 23rd July 2014, 22:05   #94
lucifer919's Avatar
Thanked: 307 Times
Yep. this is quite common with a lot of battery dealers. We changed the batteries on 3 Palio 1.6s recently and each dealer was trying to push the Amaron DIN 45 simply because they did not have stock of the Exide Din 50.
From asking around, was informed that Exide is the only one that manufactures the DIN 50 and they seem to be hard to come by unless the dealer specifically asks for them to be sent out. Not sure why and maybe i was mislead with this bit of info.
lucifer919 is offline   Reply With Quote
Old 23rd July 2014, 22:21   #95
bejoy's Avatar
Thanked: 409 Times
Exide DIN50 is way too expensive, even higher than DIN55. My Palio 1.2 is running on DIN45 (third battery) for close to 5 years now.
My previous one was DIN55 and the original one came with car was DIN50. Ironically the current one is the most lasting of them all.
bejoy is offline   Reply With Quote
Old 24th July 2014, 00:16   #96
chakri400's Avatar
Thanked: 99 Times
Glad to know din45 works and works better! I can sleep tight now 😃
Old 4th September 2015, 13:53   #97
Abhi_abarth's Avatar
Thanked: 111 Times
Bumping on an old thread. My palio S10 needs a battery replacement. Can anybody tell me what is the OEM specification for the same and which brand to go for.
Battery bhai says 45 AH while choosing the palio petrol option (no 1.6 available).
Please help.
Abhi_abarth is online now   Reply With Quote
Old 4th September 2015, 14:46   #98
vipul_singh's Avatar
Thanked: 230 Times
Amaron Flo 45AH works very well on the 1.6, going by my experience. The critical number - Cold Cranking Amperes (CCA) - is around 350 which is much more than the amps required on the 1.6 (250 as per the workshop manual).
If you can get Amaron Pro 45 AH (with CCA of over 500), nothing like it. Despite being smaller than DIN 50, it lasted 8 years in my 1.6
vipul_singh is offline   (1) Thanks Reply With Quote
Old 4th September 2015, 15:19   #99
vrprabhu's Avatar
Thanked: 351 Times
Question -
Answer -
SunnyBoi has a s10 if I am right....
Exide DIN50 fits snugly in the battery compartment. DIN 45 is smaller & DIN55 may not fit.
I am using Amaron Flo 45AH on my 1.2 nv Sport since last three years. Touch wood, I haven't faced any issues so far.
Personally my experience with Exide (both car and bike) batteries haven't been good. Amaron seems to be better performer (car) and AMCO was my preferred brand for bikes.
BTW, I purchased Amaron from BatteryBhai and got the best deal. Delivery and fitting was on schedule and the battery was just three months old (i.e. mfg. date) when I bought it.
vrprabhu is online now   (2) Thanks Reply With Quote
Old 5th September 2015, 00:23   #100
SunnyBoi's Avatar
I had a S10
DIN45 is smaller but is still a snug fit. I have the original battery strap so the battery doesn't move about despite it being smaller.
Palio Battery options DIN50/DIN55 and manufacturers-img_20150816_150352001.jpg
Cruisers in India - Do we need more options from manufacturers ? TaurusAl Motorbikes 26 20th January 2012 13:53
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Strike affects battery supplies to motorcycle manufacturers! anjan_c2007 Motorbikes 3 4th July 2010 17:16
Help on Shifting from DIN50 to DIN55 and Which Brand? gemithomas Technical Stuff 2 10th June 2009 13:33
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
