Old 8th January 2010, 20:53   #1
humm's Avatar
Exclamation Hot Battery terminal?
Hello,
Today I was swiping one battery between two cars.
Car1: Battery terminals perfectly -- ok. Terminals are normal temperature.
Car2: When battery was connected and moved etc, while removing the battery, I found the NEgative terminal of the battery to have become HOT!
Someone told me maybe the connectors are loose. I found out it was a bit loose, therefore I removed the battery again and connected everything properly. Switch on the car for few minutes and close the car.
I check the battery terminals again. Positive terminal seems to be normal temp, again the negative terminal is a bit HOT.
Is everything ok??
humm is offline   Reply With Quote
Old 9th January 2010, 11:58   #2
Thanked: 245 Times
check alternator output and grounding.
Old 9th January 2010, 12:09   #3
clevermax's Avatar
Thanked: 445 Times
There is some loose contact there which makes the terminal hot. The loose contact provides a path with more resistance and thus it heats up when current flows. Just grind the terminal a bit to expose some good metal surface and the fix the connectors.
clevermax is offline   Reply With Quote
Old 9th January 2010, 22:15   #4
vigsom's Avatar
Thanked: 610 Times
Is everything ok??
What is the cable like in both cars? look the same?
In any case,the negative should not get hot
if you could post pics of the same battery fitted in cars 1,2 maybe we can deduce something
Old 9th January 2010, 22:33   #5
Thanked: 149 Times
Check alternator circuitry. It may be that alternator charging current is too much.
Old 9th January 2010, 23:43   #6
humm's Avatar
Wiring, setup everything is perfect. I'll verify the system again tomo and report back.
Old 10th January 2010, 19:31   #7
R2D2's Avatar
Thanked: 2,055 Times
The loose contact may have messed up the internal connectors from the --ve terminal to the plates. Also, internal resistance caused by sulphation can cause a battery to heat up.
When you get the charging system checked, get the battery load tested as well. Make it a habit to check the battery water levels + cable clamps regularly and fill the cells with distilled water/tighten the clamps as required.
Cheers!
Old 13th January 2010, 00:31   #8
Thanked: 660 Times
its the case of loose contact I guess.
Just curious, is the battery of same amperage?
Audi Mobile Terminal (Mobile Audi showroom) launched in India Aditya Indian Car Dealerships 3 23rd September 2015 15:28
Volvo Lounge @ Terminal 3, IGI Airport, New Delhi rajneeesh The Indian Car Scene 1 8th November 2014 21:09
Airport-like Bus Terminal in Vadodara, GJ Mpower Commercial Vehicles 18 14th October 2014 13:20
Panasonic Base Terminal - Useless Battery indicator tsk1979 Technical Stuff 6 12th July 2009 16:37
Battery Terminal Coat - It it worth ? mithun Technical Stuff 4 27th April 2009 12:31
