Old 9th January 2010, 13:24   #16
Thanked: 40 Times
Rehaan,
Nice pictures man !
I liked the ITW stall pictures, being the company which gave my first break in my professional life.
nandans2005 is offline   Reply With Quote
Old 9th January 2010, 13:30   #17
Rehaan's Avatar
Thanked: 25,043 Times
Default Indian Machine Tools
Indian Machine tools had on display some equipment for testing fuel-injectors.
Basically its a machine similar to a lathe, which is connected to a pump (rotary pump in this case), which forces coloured liquid through the injectors.
The liquid then collects in individual test-tubes where the exact amount that passed through each injector can be measured.
This is a linear pump
Old 9th January 2010, 13:31   #18
nikhil1300's Avatar
GOOD THREAD waiting for more pics and up dates
nikhil1300 is offline   Reply With Quote
Old 9th January 2010, 13:36   #19
Rehaan's Avatar
Default Gibraltar
Gibraltar makes air-springs used in busses and trucks, though at the moment in India, busses are their main business (eg. volvo) - but typically this technology gets used in commercial applications before making its way to the trucks, which eventually overtake the busses.
The air-spring consists of a top and bottom metal cap, and a thick rubber bellow (the actual air-spring) between them.
There is a inlet at the top and the air-spring is typically filled to about 4-bar of pressure (ie 58psi).
The bursting pressure of the bellow is closer to 22bar (320psi)
Old 9th January 2010, 13:41   #20
Rehaan's Avatar
Default Wipro
Wipro develops the software for many automobile applications.
One of them is instrument clusters.
Shown below is the instrument cluster from the Ferrari California - which uses the Wipro's solutions.
Old 9th January 2010, 14:03   #21
Rehaan's Avatar
Default Dentmasters
If i'm not mistken, Dentmasters is the name of the Indian company that uses equipment from this particular manufacturer.
This is a plastic staple machine, to be used when your bumper gets a cut in it.
Basically the yellow device heats up the staple, which is then pressed into the bumper (as can be seen), holding each side of the cut together.
The metal pins sticking out are then cut off, and the bumper is then finished and painted.
This is a pretty cool device for "pulling out" dents.
The tip is basically a spot-welder - you touch it to the metal and an electric current passes through it for a split second, welding the point to the body panel.
After that, the squeeze-grip (left hand) can be used to slowly pull the dent out. This gives more control than a suction device.
Twist the top handle to release the welded point from the bodywork.
(Bottom right of the frame is the grounding for the welder)
Old 9th January 2010, 14:07   #22
Rehaan's Avatar
Default KKI Auto Parts
Some sort of splined shafts -- any idea what these are used for?
They look like they would be a neat design for a flashlight.
Old 9th January 2010, 18:55   #23
Thanked: 294 Times
Axle transmission in trucks. The long spline is for the flexibility when the axles moves.
Old 10th January 2010, 14:50   #24
Excellent info Reehan, I am waiting for more.
autospirit is offline   Reply With Quote
Old 10th January 2010, 19:24   #25
Rehaan's Avatar
Excellent! Thanks LBM.
Any pics of it as installed?
8-10 more posts coming up tomorrow!
cya
R
Old 11th January 2010, 11:52   #26
excellent stuff rehaan, this section is something which lets us learn quite a good things.Now who would know wipro technology also works for instrument cluster and its also works fits in ferarri as well.Awaiting to read more from your side.
vijaythacker is offline   Reply With Quote
Old 11th January 2010, 12:20   #27
Thanked: 9 Times
good pics and very nice info Rehaan. Great job, not just here but in all the other threads too!
Abhay is offline   Reply With Quote
Old 11th January 2010, 12:45   #28
Rehaan's Avatar
Default Vikas Engineers
A nice selection of valves from the Accent to the Zen...
Old 11th January 2010, 14:15   #29
Rehaan's Avatar
Default Crh
Seat manufacturers in the Germany stall.
I really loved the look of these bare seats - the way they are manufactured and the amount of little details in them is evident in this form.
The electic motors of the seats were connected to buttons on the display and you could move the seat (electric recline on the one shown below)
Heres a close-up of the motor. Fairly small right?
Probably a worm gear driving a small gearset in there...
They even had a seat from the new E-Class on display.
This one is from the i30
Old 11th January 2010, 15:43   #30
Rehaan's Avatar
Default Freescale Semiconductors
Okay here is a really cool one!
Moreso for the presentation and demonstration kits than the product itself.
Dashboard cluster showing the LCD screens and dials
They had these really cool portable suitcases for demoing control systems for small engines
Here you could see all the essential components that are part of the control system, as well as have the ability to tweak values like the air intake temperature or whether the kickstand is up or down.
Another similar demo-in-a-suitcase was this one - for controlling all the lights on a vehicle, as well as central locking actuators (those gun shaped black things) etc.
Pressing the buttons on the keypad toggle the lights.
The three black squares on the big circuitboard on the left are the substitutes for mechanical relays. (Relays take up space and add an increased failure probability to an electrical system, since they have moving parts).
Each square chip can replace 4 relays - so in essence this board can handle the job of 12 relays.
I'm not 100% sure - but i bet it also handles functions like interior light dimming, follow-me-home headlights etc, which traditional relays and switches wouldn't be set up to do.
As Ported_Head mentioned - these travelling demos would be a great teaching tool at engineering colleges etc - Freescale should consider doing short visits, as it will be good for practical learning, as well as educating the future engineers about their brand!
ACMA organises first 'Tech Expo' for Indian auto component companies in the USA S2!!! Technical Stuff 0 8th July 2014 19:04
Mahindra 2 Wheelers to merge with auto and farm equipment biz JayPrashanth Motorbikes 0 14th October 2013 10:12
AUTO EXPO 2010 - Live Feed & Pics Latheesh The Indian Car Scene 614 10th January 2011 15:16
Wheelosphere at The Hindu Chennai Auto Expo » The Hindu Chennai Auto Expo 2010 udayjani The Indian Car Scene 3 10th October 2010 16:54
Vintage & Classics at the Auto Expo 2010 S.B.Jatti Vintage Cars & Classics in India 32 7th March 2010 03:16
