Old 9th January 2010, 12:22   #1
Rehaan's Avatar
Thanked: 22,583 Times
Default Component & Equipment Manufacturers at Auto Expo 2010
A huge part of the Auto Expo is taken up by component manufacturers, OEM suppliers and auto-equipment dealers. Pretty much an auto-parts trade fair.
Its not just India that these companies cater to. A lot of it is export - for brands like Ferrari, Peugot, John Deer etc.
Just walking through a few of the halls gave us a chance to see pistons, cam-shafts, valves and heads ranging from tiny 50cc motors to massive earth-moving equipment.
Here's a hand-picked selection of some of the cool things on display :
(I'm still adding to the thread, so keep checking back)
Old 9th January 2010, 12:25   #2
Rehaan's Avatar
Default Anand Pistons
The friendly gents at this stall wanted to be in the picture
Absolutely massive pistons made for earth-moving equipment.
Thats a 13.7cm bore!
Some perspective on how large it was
Beautifully machined. This is a work of art in itself!
Old 9th January 2010, 12:33   #3
Rehaan's Avatar
Default JNS Instruments
These guys make some top-quality instrument clusters!
This is from the Euro-spec Civic. The front is made of acrylic that is shaped to be a bit of a lens, giving an awesome feel of depth to the instrument cluster. Absolutely gorgeous!
Here it is in the real-world
Source : http://www.carbodydesign.com/archive...nterior-lg.jpg
The person there said this might have been from a GM car sold in Japan - any idea which one?
Old 9th January 2010, 12:38   #4
Rehaan's Avatar
Default Sarita Forgings
These guys make forged components (much stronger than cast components), which are then machined down to exact specifications.
Thats a connecting rod in its forged form (connects the piston to the crankshaft). It will be machined down, and even cut at the bottom so that it can be fastened onto the crankshaft.
Old 9th January 2010, 12:43   #5
Rehaan's Avatar
Default National Semiconductor
This company makes the LED drivers for headlamps and taillamps. (ie the circuitry to power the LEDs and not the actual headlamps)
Here the main beam is a HID, but everything currently lit up is LED.
The 3 projectors at the top use a 4watt LED each (the kind you find in top-end LED flashlights). No active cooling (fans) required, but naturally there are heat-sinks for the LEDs. Pretty bright!
The LED brakelights use a bunch of 25ma LEDs.
The advantage of LED taillights is that :
1) They don't burn out like regular incandecent bulbs
2) They light up to full power a few milliseconds faster than any filament bulb does - hence cutting down on reaction time. Even a 100ms faster reaction time can in theory save you meters of braking distance when travelling at high speeds.
Last edited by Dippy : 15th January 2010 at 17:44. Reason: Editing on condor;s recommendation :)
Old 9th January 2010, 12:48   #6
Rehaan's Avatar
Default SDS Automotive
A collection of valves
Fluid lines - very sculptural no?
MASSIVE connecting rod!
HUGE brake shoes and pads
(Does anyone know what that rubbed cone is? and why there seems to be one on the brake pad as well?)
Smooth as silk cylinder sleeves
Old 9th January 2010, 12:51   #7
Rehaan's Avatar
Default Minimeter
Dials and guages for Mahindra, Reva etc
The collection...
Old 9th January 2010, 12:52   #8
Rehaan's Avatar
Default Luthra Industrial Corp
Massive brake drums and brake shoes for busses
Old 9th January 2010, 12:55   #9
normally_crazy's Avatar
Thanked: 387 Times
Good Stuff Rehaan. Good to the back guys on the front pages for a change.
Any more ?
normally_crazy is offline   Reply With Quote
Old 9th January 2010, 12:56   #10
Rehaan's Avatar
Default WITTE Modular Fixtures
From the "Germany" Pavillion (which had some really nice stuff) - this was one of my favourites from the expo.
Anyone who has ever laid out a frame or chassis for welding will know how hard it is to jig it up PERFECTLY - and that every millimeter that your project gets skewed results in much more heartache with the other components down the line.
Witte provides a very neat and solid modular system (ie can be configured to any size, in many ways) to lay out or hold your work - whatever be the purpose.
Here you can see how the modular blocks are attached to each other - and clamps or various other holding devices are attached to the backbone of the system.
Old 9th January 2010, 13:01   #11
Rehaan's Avatar
Any more ?
True - i really enjoy this part of the expo. Unlike the car stalls where you mostly get new info, walking around the component manufacturer stalls gives you a chance to actually see things in their basic form as well as LEARN a lot too.
Yes, about 25 more stalls to be posted in this thread
cya
R
Old 9th January 2010, 13:03   #12
Rehaan's Avatar
Default ITW Chemin
ITW definitely took the "green" theme of the auto expo to the max!
Check it out - they even had a mini-golf putting strip.
Old 9th January 2010, 13:06   #13
Rehaan's Avatar
Default ANG Auto
Looks kinda like Arnie's gym.....
These are some heavy-duty axles. Look at the thick cross-section (painted red) of the housing!
Old 9th January 2010, 13:09   #14
Rehaan's Avatar
Default Madhus Garage Equipments
Heres a equipment dealer for a chance of pace.
Dealing in high-tech wheel balancers, alignment tools etc
@Nikhilb2008 - had come by to say hi, but they said you were not around.
When i asked "Is Nikhil there?" their reply was "Are you a BHPian?"
Old 9th January 2010, 13:12   #15
Rehaan's Avatar
Default TATA Elxsi
Remember the Tata Manza website where you can see a 360* view of the car and its interiors?
Tata Elxsi is responsible for those creations and other CGI work. Yep its a Tata owned company.
On the screen was some of their animations for the new Tata Venture IIRC
ACMA organises first 'Tech Expo' for Indian auto component companies in the USA S2!!! Technical Stuff 0 8th July 2014 19:04
Mahindra 2 Wheelers to merge with auto and farm equipment biz JayPrashanth Motorbikes 0 14th October 2013 10:12
AUTO EXPO 2010 - Live Feed & Pics Latheesh The Indian Car Scene 614 10th January 2011 15:16
Wheelosphere at The Hindu Chennai Auto Expo » The Hindu Chennai Auto Expo 2010 udayjani The Indian Car Scene 3 10th October 2010 16:54
Vintage & Classics at the Auto Expo 2010 S.B.Jatti Vintage Cars & Classics in India 32 7th March 2010 03:16
