Old 14th January 2010, 12:43   #1
Thanked: 57 Times
Default Hyundai Accent coolant leakage problem
Car: Hyundai Accent
Last week the hose pipe which connects the radiator to the engine developed a small cut and the coolant started leaking. This was the 1st issue ever recorded in my car, so I had no idea how to get back home (was at the other end of the town).
Called up Vijay (Star_aqua) and he told to use the red tape so that it will stop the leaking to an extent (my idea was to use M seal but cancelled). Finally head back towards home praying that the car does not break down. The temperature was increasing drastically and after 10-12 kms the car stopped. Cos of the tape I could at least cover 10 kms (Thanks to Vijay).
Called up just dial to get Hyundai hotline number. And as usual they sent all possible numbers except hotline number. Using cell phone searched on Google and found the hotline number. Man, I must say that the hotline guy was very helpful. He made me understand the situation , told me to hold on for 20 minutes till the engine cools down and then open up the radiator cap and fill 3 litres of water.
As I opened up the bonnet I found that the coolant (green thingy in the box on the left) was still full. I asked him whatís the funda as the coolant from the box is supposed to go to radiator if the coolant level is less in the radiator. He said thatís not how it works and we need to fill water. As that was not the place to discuss about the technicalities, did whatever he told to and somehow dropped the car in Advaith Hyundai at 11:30 in the night. Got it fixed it next day.
My question here : Is it true that the coolant which was in the box does not go to the radiator if the level is low in the radiator ?
livyodream is offline   Reply With Quote
Old 14th January 2010, 19:34   #2
vigsom's Avatar
Thanked: 604 Times
The expansion bottle(coolant box as you have described) works like this:
  1. when the car is started and the coolant temperature begins to rise,there is a rise in pressure in radiator causing the radiator cap pressure relief device to release some coolant into this expansion bottle
  2. When the car is stopped and the engine cools down,the coolant also cools causing the radiator to go into vacuum.The radiator cap has a vacuum relief device which allows coolant to flow in from the expansion bottle.
So the expansion bottle serves the purpose of a buffer for the coolant in both cases.
In your case,the hose leaked causing coolant in the radiator to escape - here your radiator cap would have continued to remain closed as the leaky hose was your pressure relief device .Hence you'd have found your coolant box ,sorry expansion bottle level intact.
Old 14th January 2010, 20:33   #3
Thanked: 57 Times
Thanks for the info vigsom. Till now I used to think it as a reservior for the radiator.
Old 16th June 2010, 13:05   #4
Thanked: 432 Times
Originally Posted by livyodream View Post
Car: Hyundai Accent
How did the cut happen in the first place? Was it an accidental damage or a pressure leak? Do you remember whether the coolant reservoir was being filled ABOVE the max mark regularly?
jinojohnt is offline   Reply With Quote
Coolant liquid leakage wanderlustindia Technical Stuff 32 30th April 2018 19:11
Hyundai Santro: Coolant Leakage from a strange location ghpk Technical Stuff 19 25th March 2015 07:29
Coolant Leakage in Esteem VX-2001 dev_kudle Technical Stuff 68 18th May 2011 23:02
Alto - Coolant Leakage - How to take my car to Service? Karim Bhai Technical Stuff 19 20th June 2010 13:47
