Old 15th January 2010, 16:46   #1
sidd25's Avatar
Thanked: 7 Times
Default Vibration in Hyundai i10
Guy, In past few days, i have noticed a strange Vibration in my i10 era.
The noise comes from behind the steering wheel, somewhere inside bonnet.
I checked the spoke used to rest the bonnet but is tight enough not to vibrate.
Do someone else is also facing a similar problem?
Please advise what I can me of?
sidd25 is offline   Reply With Quote
Old 15th January 2010, 17:03   #2
yogeshnaik's Avatar
Thanked: 41 Times
At what rpm does it sound? Keep the vehicle stationary, start the engine, open the bonnet and try to rev up the engine and observe. If it does not reproduce the vibration, then it might do during movement. Check the rubber bushes which are linked to the Anti-Roll bars, and front wheels.
yogeshnaik is offline   Reply With Quote
Old 15th January 2010, 17:24   #3
sidd25's Avatar
Thanked: 7 Times
It does not vibrate on smooth road. But on uneven road.
Old 15th January 2010, 17:29   #4
pramodkumar's Avatar
Thanked: 947 Times
Do you feel your steering pulsating? If yes then you need to get the tie rods and ball joints checked.
Pramod
Old 15th January 2010, 17:41   #5
yogeshnaik's Avatar
Thanked: 41 Times
Do you ever had a thud sound on uneven roads? Get the joints and balancing rods checked as soon as possible.
Old 15th January 2010, 18:10   #6
wildon's Avatar
Thanked: 1,061 Times
Its a common issue in i10 and i20's . knocking sound when on rough roads. Get it checked and they will replace the parts. Its related to the steering assembly.
wildon is offline   Reply With Quote
Old 15th January 2010, 19:08   #7
Mi10's Avatar
Thanked: 1,459 Times
Its not only vibration, its rattle rattle rattle all the way
..and we thought a 2 year old Swift, rattling is bad
Mi10 is offline   Reply With Quote
Old 15th January 2010, 23:27   #8
vigsom's Avatar
Thanked: 604 Times
Sidd,does the noise stop when you slightly depress the brake pedal?If yes,it is the caliper pins
Hyundai i10 AT Sportz - Hyundai Stock / Brand Value in the Eyes of a customer ACM Test-Drives & Initial Ownership Reports 16 18th November 2012 13:53
Advaith Hyundai loses my Hyundai i10! Cops find it, car lying at Police Station sandeepmohan Indian Car Dealerships 68 22nd August 2012 08:57
Clutch vibration in new i10 AntibiotiX Technical Stuff 2 1st December 2009 17:03
Vibration in Accent CRDI badri Technical Stuff 9 29th December 2008 18:15
