Closed Thread
Old 17th February 2013, 16:31   #76
joshuakeys's Avatar
Thanked: 53 Times
Default Re: Shuddering/Vibrations while braking! Need help!
I had a similar issue with My accent Viva with ABS, Initially i thought its the break pads issue, so got it changed, The problem was not solved, Then got the Disks resurfaced, issue resolved, You don't have to change the disks for such a small issues.
joshuakeys is offline
Old 17th February 2013, 18:16   #77
Thanked: 370 Times
As a rule of thumb, if you car has major shuddering only when braking, the reason is generally a warped disc/rotor. It could be that you need to change the brake pads if the rotor is OK.
Another possibility, though much rarer is that of something (usually small stones) getting stuck in between the pads and disc.
An unbalanced wheel will result in shuddering all the time.
pganapathy is offline
Closed Thread
Annoying problem while braking.. ashthedivx Tyre & Alloy wheel Section 13 10th February 2017 12:03
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
Problem while braking throttleking Technical Stuff 22 1st June 2009 11:40
A strange sound while braking zaks Technical Stuff 2 11th February 2009 22:24
Vibrations under hard braking RJK Technical Stuff 15 21st July 2005 13:42
