Old 21st January 2010, 01:57   #1
Default Whistling noise in AC vents
I have an Elantra and am hearing this whistling noise whenever the blower is turned on.Seems to increase in pitch when the speed of the blower is increased. I tried shutting off the different vents but still the noise seems to exist.
Before taking it to Hyundai I was going to check the AC filter to see if it is clogged.Anybody have a similar issue?
bdubya is offline   Reply With Quote
Old 21st January 2010, 09:29   #2
falcon009's Avatar
Maybe some small particle is stuck in the vent. It happened to my car once but after increasing the fan speed to max the sound became non existent
falcon009 is offline   Reply With Quote
Old 21st January 2010, 10:14   #3
jav
Has the air flow decreased or increased? maybe one of the vents are partially stuck.
jav is offline   Reply With Quote
Old 21st January 2010, 23:32   #4
I'm not really sure if it is a dust particle as I cycled thro all the vents at max blower speed with the other 3 vents closed.
About the air flow - it is not reduced atleast no significantly
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
1.2 nv gear humming noise from ac vents kapilsharma80 Technical Stuff 0 30th May 2008 11:46
Whistling Soung from Blower mobike008 Technical Stuff 9 21st February 2008 01:05
whistling sound Thomas T Technical Stuff 3 14th December 2007 10:15
Whistling noise from the engine Deeps Technical Stuff 10 24th November 2005 18:06
