Old 21st January 2010, 15:12   #1
adrian's Avatar
Thanked: 602 Times
Default Bolero Wheel problem
Hello Friends,
I am hearing clicking noises the left wheel when the steering wheel of my Bolero is fully locked to the left. No problems when the vehicle is moving straight and around small bends. Any idea?
adrian is offline   Reply With Quote
Old 21st January 2010, 16:20   #2
Pankaj401's Avatar
Seems like outer CV joint of the drive shaft. Get both, left and right, checked.
Pankaj401 is offline   Reply With Quote
Old 21st January 2010, 16:30   #3
shishir_bn's Avatar
Thanked: 108 Times
Sometimes when the tyrers are changed(from stock tyre to one available in the market) and when you do a full turn, inside of the tyre might be touching the components
shishir_bn is offline   Reply With Quote
Old 21st January 2010, 17:02   #4
Spinnerr's Avatar
Thanked: 155 Times
Adrian,
Could you put up some more details, Tyre size, are alloys used (with lot of -ve offset)?
Did the issue crop up all of a sudden? or after a type / alloy upgrade?
Spinnerr is offline   Reply With Quote
Old 21st January 2010, 17:11   #5
vinod_nookala's Avatar
Thanked: 416 Times
Originally Posted by adrian View Post
Hello Friends,
Please get your power steering belt checked. Lock to lock noise that should be the problem.
@pankaj- Bolero is a rear wheel drive vehicle. Hence drive shaft on each end do not exist.
vinod_nookala is offline   Reply With Quote
Old 21st January 2010, 17:24   #6
Pankaj401's Avatar
Hey thanks for the insight. Guess I was too sleepy to think after a heavy lunch.
Old 22nd January 2010, 13:37   #7
adrian's Avatar
Thanked: 602 Times
Originally Posted by Spinnerr View Post
Adrian,
I am using stock tyres (Radial P215)
Old 22nd January 2010, 13:44   #8
adrian's Avatar
Thanked: 602 Times
Default Hi Vinod,
A belt problem would give a loud squeal. I had this problem once.This is clicking noise. Could it be a bad valve or bearing in the power steering pump?
Old 22nd January 2010, 14:09   #9
Thanked: 416 Times
You are right about long squel. Please get it checked at workshop. Only personal inspection can source this problem.
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
Bolero 4x4 - ECM Problem whitemm550 4x4 Technical 51 6th April 2014 19:46
starting problem in me ole Bolero GLX chaunfa Technical Stuff 14 2nd March 2010 22:52
