Old 28th January 2010, 11:02   #1
Wind splitter's Avatar
Default M800 issues
About quite some time back I ran over a road hump at the speed for 80KMPH and since then front left wheel of my M800 makes tacking sound, this sounds comes during the initial move and while taking the turns. As per MASS this is an issue with front left wheel drive shaft and I was asked to ignore it .
My car is running on 12 NEO wheels, Bridgestone Potenza G3 165/60R/12. Rear suspension has been raised a bit as after the upgrade of the wheels rear tire was scrapping the body wall. I feel the ride is not smoother, its little bumpy.
Engine response is not all that great, feels as if its struggling hard at initial stages at lower RPM . Gurus and BHPians please help me fix above issues.
Car M800 CARB 1998, clocking 28K KMs.
Wind splitter is offline   Reply With Quote
Old 28th January 2010, 13:18   #2
sumeethaldankar's Avatar
Thanked: 1,161 Times
Push down the car at the front end side at the corner and hear for any clunking sounds.If the driveshaft has a issue why has the MASS asked you to ignore.Check for the CV boots on either wheel and see if its intact.Does the sound comes while driving overpotholes and humps.get your suspension inspected by a comepetent garage.
sumeethaldankar is offline   Reply With Quote
Old 28th January 2010, 14:11   #3
Hashim's Avatar
Thanked: 32 Times
I think you have bent front disc, take out the wheel and look for any deep scratches on the disc. Of maybe Calipers or pads are misaligned due to impact. Also check axle nut (big nut in the center), it might be slightly loose.
Hashim is offline   Reply With Quote
Old 28th January 2010, 15:37   #4
Psycho's Avatar
Thanked: 95 Times
Sounds like a worn out driveshaft and it would be better if you replaced it as per the MASS instructions.
Old 28th January 2010, 15:41   #5
WDM007's Avatar
Thanked: 12 Times
MASS has told him to ignore the problem
WDM007 is offline   Reply With Quote
Old 28th January 2010, 15:53   #6
MASS says this can be ignored as the sound is not loud. Please do suggest some good mechanics thatI can consult for this.
I dont think tacking sound comes when I am driving over potholes and humps how ever I will check it once again, it is noticed only during the first move and while making the turns.
Old 28th January 2010, 16:54   #7
driveshaft for sure. if you can live with the sound you dont need to change it immediately. but if it bothers you change it to either ac delco or inwell. other brands suck big time.i had the same issue in my 800 had to change within six months cause i chose to use the cheaper one
manek is offline   Reply With Quote
Old 28th January 2010, 17:30   #8
rocky080's Avatar
Thanked: 35 Times
hi wind splitter this is definitely a drive shaft problem. i have a 1987 model M800 i have changed it around 3 times now on each side. so if you can live with the sound fine or change it with MGP (maruthi genuine parts) spares. I have been getting my vehicle done for 15yrs at a place near ejipur called mythri automobiles who was previously a maruthi authorised service station now has gone private. PM me if you need the number.
regards
rocky
rocky080 is offline   Reply With Quote
My m800 and the various issues i'm having with it.. eternalck Technical Stuff 29 23rd November 2008 13:54
Alloys For M800 kakx Tyre & Alloy wheel Section 15 29th December 2005 18:28
Air Filter for M800 K&N / Others?? kakx Modifications & Accessories 6 6th July 2005 01:59
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
m800 vs alto bharatp Hatchbacks 22 3rd January 2005 02:41
