| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Just thought I'd share this little tid bit of experience and kick off a thread on it... My fuel tank was damaged by a tow truck while lifting the car for illegal parking (a whole separate story) and I wanted to get it welded (should that be "braized"? not sure) ... The leak was from a hair line crack and petrol was wetting the bottom surface of the tank, but not dripping, so I judged it "safe to drive"... I refrained from filling it and kept just as much petrol as I thought was neccessary to get me to a nearby MASS and a little more just incase I needed to drive out. I know from experience that my Esteem tank holds exactly 7L when the fuel indictor is on the "E" mark... and I know that the car averages between 13 - 15 Kmpl... I set out for the MASS at Thane (Navnit Motors on Kholshet Road), about 5 Km away from my place, when I was into my last 30Km and parked the car in the only slot available... with the car tilting about 15 degrees to the left. The MASS was choc-a-bloc with flood damaged cars and they told me that the earliest they could even look at my car was 2 months! I decided to drive to the a local auto welder, but, when I tried to start her up, the engine came to life, coughed a bit and then went died... strangely, I could hear the fuel pump whining away continuously (it normally stops in a few seconds when the engine stalls) ... and I realized what was happening! There was probably the last 1 - 2 liters in the suitcase shaped tank that was about the size of the rear seat... it could not have been more than 1/2 inch deep petrol... and the car was parked tilting sideways... The MPFI Esteem's fuel pump sits inside the fuel tank and sucks fuel from the center. With so little fuel in the tank and it being parked tilting sideways, no fuel was getting to the fuel pump intake! I ended up having to buy an empty gallon, buy more fuel and fill her up a bit before I could get her started, even though I had enough of fuel to go where I wanted to! So, here's my two paise's worth of advice (ain't got 2 cents )When low on fuel: 1. Don't park on tilted surfaces as far as possible! 2. Know the position of your fuel intake pipe in your Petrol tank and park with the car tilting towards it if not on a level surface. 3. Don't leave the ignition on when the Engine is not running, if the fuel pump runs dry for too long, it will be ruined. Other obvious stuff: - Dont run the AC - Dont rev unneccessarily; stick to highest gear possible without knocking - Dont idle unneccessarily I have heard people say that one should not let the fuel level go so low because then dirt & water from the bottom of the tank will get sucked into the fuel pump... can't understand the logic of that cuz I have seen that the FP sucks fuel from the BOTTOM of the tank! That's where the water / dirt would collect anyway! Right? Guys & Gals, contribute anything else you think may be useful... - T u r b o C - |
| Thread Tools | |
Similar Threads | ||||
| Ambassador with a 4.5 Liter, 6 cyl FORD engine!! | n_aditya | Modifications & Accessories | 56 | 27th January 2008 20:35 |
| Aveo 1.4 Petrol Base Variant or Swift ZX Petrol | amitsethi100 | Hatchbacks | 23 | 27th October 2007 20:04 |
| The reason behind the 1.2 liter engine rule? | Rtech | The Indian Car Scene!! | 33 | 15th April 2007 10:56 |
| Is it possible to dump a 1.0 or 1.3 liter block in the Maruti 800? | zero_lagg | Modifications & Accessories | 6 | 23rd August 2005 10:18 |
| Of all the things... | need4speed | Street Experiences | 9 | 17th April 2004 06:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
