Old 3rd February 2010, 10:23   #16
Ford Rocam's Avatar
Thanked: 16 Times
Originally Posted by wildchild4lyfe View Post
off late my car started stalling everytime i put on the ac or redlined it..
got everything checked and scanned a zillion times nothing showed..
finally i got an ecm from another aveo and the car was fine..!
ok few questions..
can the aveo/optra ecm be repaired?
If it stalls during a.c or redline the vibrations are causing the ecu to stall indicating probable rare cause of dry solder joints. have get that checked before going to next step.
Ford Rocam is offline   Reply With Quote
Old 3rd February 2010, 10:35   #17
wildchild4lyfe's Avatar
Originally Posted by nitrous View Post
+1.
I think its like repairing mobile phones, other electronics.
Replacing is a far better option.
yea i think ill do just that..
hey bud! could you elaborate a bit...thanks..
wildchild4lyfe is offline   Reply With Quote
Old 3rd February 2010, 12:31   #18
pranavt's Avatar
Thanked: 274 Times
The soldering that has been done on the ECU could have a few dry solder joints (look those up on google/youtube). These solder joints are weak and in a car's harsh environment, can get loosened, or weak very quickly. Checking for these should be as easy as opening up the ECU and using a multimeter to go over the various connections and checking for continuity. Of course, if you are a hobbyist or an electrical engineer only
Old 3rd February 2010, 13:42   #19
well i am a hobbyist and i know that the solders are on the ecu board..but then it aint on screws so how do i seal it back on...would silicon do?
Old 3rd February 2010, 14:44   #20
pranavt's Avatar
Thanked: 274 Times
Suck up the bad solder using desoldering braid and resolder the joints.
Old 3rd February 2010, 14:53   #21
@ Pranav: nah man thats not what im talking about..its the metal case outside.
they dont have screws and mechs told me that once opened it cant be refixed..
Old 3rd February 2010, 14:58   #22
mdesai_1981's Avatar
but this is a sealed box. and a lot of mechs have told me that it cant be repaired..are you sure about this guy mihir?
well actually i have seen this guy actually repairing it. also there is a technique to seal it. what they use is unknown what i feel is you get it repaired and try it if your purpose is solved by paying 1/10th the price why not else you go for a new one if it is not to your expectation.
also you can try at KURLA on CST road there are a lot of scrap dealers. they def must be having one. try it out.
last resort you should buy a new one.
mdesai_1981 is offline   Reply With Quote
Old 3rd February 2010, 15:46   #23
PJSPEED's Avatar
Have you tryed taking the instrument cluster fuse ??
PJ
PJSPEED is offline   Reply With Quote
Old 3rd February 2010, 16:00   #24
007
007's Avatar
Default Are you sure
ECM is the last part to be blown down the line.
Are you sure you have not tried any mischiefs with the ECM ( remapping, piggy's, or any signal modifier acts) ?
However the only solutions for the cases like this is replacemnt with new one ( similar make) .
007 is offline   Reply With Quote
Old 4th February 2010, 10:03   #25
Post Deleted by the Team-BHP Support : SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper English in posts, for the benefit of other forum users.
Also, avoid typing with excessive dots.........like............this................. .
Please view our board rules carefully before proceeding any further.
wildchild4lyfe is offline   Reply With Quote Received Infraction
Old 8th February 2010, 18:22   #26
well we scanned the car a lot of times. ok so yea, i have a doubt about the alternator aswel.
Old 17th February 2010, 14:22   #27
ok so i was on the highway on my way home. and the alternator belt snapped.the alternator belt and the fan belt are the same thing right? im not sure cz my driver got a mechanic home and he told me over the phone that it was the fan belt.so got that replaced and now the car refuses to start. it is cranking but the compression seems to be very low.
ok can any of you guys give me a solution? or does anyone here tell me what could really be wrong with the car??
the mech was telling me that the car couldnt handle the load from the system.well my system aint that big a banger anyways.
so yea help!
Old 17th February 2010, 14:57   #28
moralfibre's Avatar
Thanked: 6,532 Times
PJ
This is exactly what I felt as soon as I heard the problem. Hard to blow an ECU.
Old 17th February 2010, 15:05   #29
yes all the fuses have been checked.
Old 16th March 2010, 12:44   #30
Thanked: 116 Times
I have a 2002 model Gypsy. I had bought it from a dealer in Mayapuri and it is currently undergoing restoration.
An electrician told me that the ECM isn't providing the "earth" for ignition; and the Mayapuri dealer had connected the ignition earth wire from battery (via body shell). He says that it's alright and will give no issues.
What do you guys suggest? Is it alright or it can cause trouble?
And can it be repaired, or will I need to replace the ECM?
Please help.
Nitin
ntomer is offline   Reply With Quote
With rising fuel prices, are small capacity blown petrol engines the way forward? MaserQ Technical Stuff 17 10th August 2011 11:13
pics of a blown toyota paras211 Modifications & Accessories 2 11th January 2008 14:40
hissing noise from speakers when horn is blown gopz In-Car Entertainment 7 14th June 2007 13:40
MS BLOWN into retirement .... khaadu75 Int'l Motorsport 2 23rd October 2006 01:01
RaceR Tech tacho blown! steroidauto Modifications & Accessories 7 5th January 2005 13:23
