Closed Thread
Old 10th September 2005, 10:59   #1
The Stig's Avatar
Default What is a double clutch?????
Hi guys ,
I would like to know what is a double clutch? How is it different from the normal clutch and how does it work? You generally find them in these very powerful cars like the Bugatti etc..
The Stig is offline
Old 10th September 2005, 11:06   #2
Domnic's Avatar
Please do a search before posting... heres a link Double Clutching (Whats double clutching & whats the reason to use it)
Dom
Domnic is offline
Closed Thread
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
