Thread Tools
Old 14th September 2005, 10:56   #16 (permalink)
devarshi84's Avatar
do let us know the results of the performance of your car.
__________________
boyracer.blogspot.com
devarshi84 is offline   Reply With Quote
Old 14th September 2005, 12:43   #17 (permalink)
Originally Posted by hrag
I normally tank up every 250 - 300 km.
How big is Indigo fuel tank? And how much you consume for those 250 km?
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 14th September 2005, 13:10   #18 (permalink)
hrag's Avatar
Not very sure about the Indigo tank but the Indica tank is 37 litres.
The consumption varies depending on traffic (jams).
For the last fill, it took in 24.997 litres for 276 km giving 11.04 kmpl. My driving is with 100% A/C in Chennai city and I normally follow the 15-30-45-60 routine for upshifting.
Some more data in case you're interested:
First tankful at odo reading 46
Latest tankful at odo reading 45308
Fuel filled: 4114.40 litres
Overall mileage over 45262 km: 11.00 kmpl
Current odo reading is 45485 which has been 90% city and 10% highway.
__________________
2003 March Tata Indica V2 LSi 92K km
1997 February Bajaj KB125 RTZ 48K km
hrag is offline   Reply With Quote
Old 14th September 2005, 13:14   #19 (permalink)
tsk1979's Avatar
Wow!! You really keep a record. I normally record for around 5000kms and then stop. Then again i start recording for few thousand kms and stop. 11kmpl is a great number for a car this size.
__________________
Reclaiming.....!
Old 14th September 2005, 13:40   #20 (permalink)
amitabh_kaushal's Avatar
Hi RX135,
Indigo tank is 42 L. I started following rules and using only HP Power, as one article in overdrive says Hp power is the second one to give good mileage. In pune i dint find SHELL petrol.
One more ? , how to reduce the front suspension noise, it irritates. It started when i put the air pressure to 30-32 psi in my 175/65 R14 GPS2 tyre. Goodyear website says to 35 psi & indigo manual says 26 psi so i opt for 30-32.
also, when i start AC, some noise comes (something like roar ) is it common in indigo. i read somewhere abt AC fan belt problem in TATA cars. Going to rectify this in coming weekend.
amitabh_kaushal is offline   Reply With Quote
Old 14th September 2005, 14:07   #21 (permalink)
hrag's Avatar
If there is moisture on the belts, you might hear a noise for a short while. This should disappear but in case it persists, ask your TASC to check the belt tension.
__________________
Old 14th September 2005, 14:14   #22 (permalink)
tsk1979's Avatar
30-32 is toooo high man. What goodyear says is the max pressure, not recommended. So you put in about 2psi above manufacturor, ie 28.
__________________
Reclaiming.....!
Old 14th September 2005, 14:16   #23 (permalink)
hrag's Avatar
Thanks tsk1979! In case people are interested, here's the record of my total maintenance expenses:
1st free service at 5000: 0
0.5 litres of coolant: 60.00
2nd free service at 10000: 1334.00
3rd free service at 15000: 111.00
4th free service at 20000: 1879.00
5th paid service at 25000: 2090.00
6th paid service at 30000: 4598.00
7th paid service at 35000: 2516.82
Silencer assembly: 1639.72
8th paid service at 40000: 4576.44
Driver side wiper: 101.00
totalling 18905.98. The costs include charges for paid service, consumables, parts (filters etc.), wheel balancing / alignment. All maintenance has been carried out only at Concorde Guindy, Chennai.
Note: although the oil change interval is 10K, I have started changing the oil every 5K since the 35K service.
I don't have the complete list of parts changed right now (not that many anyway) but will surely include the complete list in my long term review.
__________________
Old 14th September 2005, 16:44   #24 (permalink)
Hi TSK,
Yes, i knew but this tyre have rating of "T" not "H" (mostly GPS2 tyre have that one). I read the tyre and MAX PSI is 44. This is the link -
http://www.goodyear.co.in/catalog_in...&PRODNAME=GPS2
Old 16th September 2005, 10:31   #25 (permalink)
tsk1979's Avatar
Does not matter. You should always keep the pressure above manufacturors recommendation. In your case 28 or 29psi would be fine
__________________
Reclaiming.....!
Thread Tools
ice for indigo xl petrol amplyfryed Ask the Gurus 3 1st February 2008 13:26
Indigo petrol? m8002? Sedans 34 18th February 2006 15:42
Indigo Petrol or Diesel NewCar Sedans 6 6th November 2005 02:30
Palio D vs. Indigo Test Drive hell_rider The Indian Car Scene!! 14 15th September 2005 01:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
