Old 15th February 2010, 14:55   #16
VTEC_Rocks's Avatar
Yeah very true.
RAC in Koramangala. I get all kinds of small work done there
Thanks much for all the help
VTEC_Rocks is offline   Reply With Quote
Old 26th February 2010, 17:05   #17
VTEC_Rocks's Avatar
Hi Guys,
I faced a new problem yesterday.
The yellow light came up when I was driving and stayed on. I pulled over and turned the ignition off. After about 15 seconds I turned on the ignition, the yellow light came up for few seconds and switched off as it is supposed to work. I cranked the engine and drove for another 4 km to reach home, the light stayed off.
Has anybody faced this kind of issue.
Need help.
Old 26th February 2010, 19:17   #18
pranavt's Avatar
Thanked: 274 Times
I have already told you how to diagnose the Check Engine Light codes.
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
WANTED: Oxygen sensor (Lambda probe) for OHC VTEC gbpscars Modifications & Accessories 5 7th July 2009 14:30
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 21:25
