Old 17th October 2007, 14:40   #16
paras211's Avatar
Thanked: 57 Times
how is the lift varied?(in bmw)
paras211 is offline   Reply With Quote
Old 17th October 2007, 14:53   #17
Thanked: 139 Times
I remember reading sometime back (perhaps 3-4 months back) that Toyota has developed a next-generation engine valve mechanism that can improve the fuel efficiency of petrol-powered vehicles by about 5-10%. The new system is also claimed to reduce carbon dioxide emissions, boost engine output by at least 10% and enhances acceleration responsiveness. The new system is called `Valvematic', and will be launched in the near future, starting with a new vehicle model with a 2.0 litre engine. The system adjusts the volume of air taken in by continuously controlling the intake valve lift volume and the timing of the valve's opening and closing. Toyota has also targeted to completely revamp its engine and transmission lineup by 2010 to reduce emissions.
vasudeva is offline   Reply With Quote
Old 17th October 2007, 15:14   #18
srishiva's Avatar
Thanked: 932 Times
Ultimately the intention is to vary the amount of fuel/air mixture let into the cylinder.
Wouldn't the future be to go for valveless engines ? Or at least for the valves to be operated not from crank/cam but electrically through other means ?
srishiva is offline   Reply With Quote
Old 17th October 2007, 15:25   #19
Thanked: 1,172 Times
OK.
Understood that "any variable valve technology has to achieve variation on the timing, duration and lift of the ait intake and exhaust valves."
Is this corect?
Now, may I know how this impacts the performance and efficiency in the following 3 conditions:
1. Low speed (steady)
2. Accelration
3. High speed (crusing)
I am looking for the theory.
Reading various sources (including Honda website), I came across some explainantion on condtion No. 3 (High Speed - steady). Let's say cruising at 80kmph @2500rpm in 5th gear on flat surface (no incline). One needs to press accelrator only little to maintain the speed and hence throttle opens only little resulting in very little air getting into the cylinder. I understood this much. What I did not understand is:
- Why is this a problem?
- Why is this called pumpng loss?
- What is being lost here? Fuel, i guess. Am I correct?
- How does VTEC solve this?
And I did not find any info on how VTEC improves condition No. 1 and 2.
Thanks in advance.
anandpadhye is offline   Reply With Quote
Old 17th October 2007, 15:56   #20
doomsday's Avatar
Post
Check out the following links(It is too detailed to post here)
BMW World - Technology
AutoSpeed - BMW's Valvetronic!
Yup. Ducati is already using it. Its called the Desmodromic Valve control system, wherein the valves are controlled by a set of rocker arms. Also another approach involves using camless engines wherein the valves will be completely controlled by the ECU, which will achieve what all VVTs seek to achieve: infinite variable valve timing.
doomsday is offline   Reply With Quote
Old 17th October 2007, 19:04   #21
doomsday's Avatar
Post
Originally Posted by anandpadhye View Post
OK.
Is this corect?
Partly correct. A VVT system seeks to achieve variation in either in the timing or the duration and lift. If a VVT system is able to vary all the three parameters, it will be more efficient. Also, it will be more complex. So a manufacturer tries to seek a balance between the efficiency and the complexity/cost involved while designing a VVT system.
2. Accelration
Thanks in advance.
1. Low speed: At low speeds, less air and fuel is needed to run the engine. This translates to lower valve lift and duration. An engine just deisgned for economy will work fine, until you demand performance from it. The valve lift and duration (due to a lower cam profile) will not be enough to fuel the engine. So you get economy but bad performance.
VTEC: Since VTEC uses two cam profiles per cylinder, the lower cam profile is the economy cam. So less air and fuel needed by the engine below a certain RPM/throttle load. Translates to good efficiency.
2. Accelaration: While accelarating, i.e. pushing the engine RPM beyond the point where the VTEC engages. In OHC VTEC, it is 4200 rpm. As soon as you cross this threshold, the solenoid powered system engages the higher cam profile. Instantly, your valves lift and duration increases. This allows more air and fuel into the combustion chamber, since the valve open quicker and stay open for a longer time.
3. High speed cruising: This depends on what your definition of high speed is. For instance, in the OHC VTEC, if you cruise around 140 kph in 5th, you will still be below the RPM threshold where the VTEC engages. This will result in very good economy since the air and fuel going into the combustion chamber will be minimum, just enough to keep the car at that constant speed. However, you are looking at top speed blasts, the VTEC will help you reach the top speed sooner if you shift right and always stay above the RPM threshold on the rev-counter.
PUMPING LOSS:
When the throttle is partially pressed, the throttle butterfly closes partially or even almost fully. The pistons are still running, taking air from the partially closed intake manifold. The intake manifold between the throttle plate and the combustion chamber has a partial vacuum, which resists the sucking and pumping action of the pistons, which in turn wastes energy. The slower the engine runs, the more the throttle butterfly closes, and more energy is lost.
Here is where i-VTEC comes in. What i-VTEC does is that it keeps the throttle butterfly fully open; while the lower cam profile is being used. This does not create a vaccum between the throttle plate and the combustion chamber, which in turn does not resist the pumping actions of the piston.
Note that this is implemented only in i-VTEC and not in the prevoius performance-oriented only VTEC implementations. (Eg. DOHC VTEC)
Old 17th October 2007, 21:16   #22
Since you guys are talking broadly about controlling valves, this might be of some interest to you. I remember reading a couple of years ago, Lotus is working on camless technology, basically the valves are eletronically actuated.
The benefits are many. To start with you can lift the valve and close it at exactly the right time and for an appropriate amount of time, basically you are in control of all parameters and you have an engine which works like it has an infinite number of cam profiles to work with. So lesser inertial losses because of lesser components to rotate. Lesser clatter because of no rocker arms reciprocating back and forth. A lighter and more compact engine. Hopefully lesser valve float. And then you can also start it with less energy. You simply lift all the valves and rotate the engine(at which point it is like a straight through duct) till it reaches the desired rpm and then leave the valves in the desired position. Think of the possibilities. Displacement on demand too will become an instant possibility, which will work more efficiently than the current system too because as far as I know in the current system, it's simply the fuel supply that is cut off, the valves do operate so you still have pumping losses.
So you finally won't have to bother with hot cams, soft cams all that. And if they do tune it softly, simply retune, and extract the best amount of torque your engine can give you at each and every rpm. Of course, it robs off a bit of the charm of an engine huh ?
2...
If you design a cam for high speeds, at low speeds the engine will not be too torquey. This is because a cam designed for a higher speed will have more lift or open for more time. Hence at lower speeds, the air will come in slowly and with less turbulence. You want to give the air sufficient velocity. So for low speeds you open the cam for lesser duration or height and to fill the same cylinder the air travels in faster, so thats more turbulence and better combustion which translates to better torque.
Sparkie is offline   (1) Thanks Reply With Quote
Old 18th October 2007, 01:21   #23
Guys...check out this link...its a detailed comparison between toyota vvt and honda vtec.
link - Bill Sherwood's VVT Vs VTEC Page
sanchits is offline   (1) Thanks Reply With Quote
Old 18th October 2007, 18:01   #24
doomsday's Avatar
Post
Originally Posted by Sparkie View Post
Since you guys are talking broadly about controlling valves, this might be of some interest to you. I remember reading a couple of years ago, Lotus is working on camless technology, basically the valves are eletronically actuated........ Of course, it robs off a bit of the charm of an engine huh ?
Yup easy to say, its gonna be difficult to implement. Think of how complex the valve train will have to be. More complexity=More reliability issues. So its gonna take some time before an infinitely variable valve timing engine comes onto a production car.
Yup, read this article long back. Very well explained for a novice to understand.
Old 18th October 2007, 23:50   #25
Originally Posted by doomsday View Post
Yup easy to say, its gonna be difficult to implement. Think of how complex the valve train will have to be. More complexity=More reliability issues. So its gonna take some time before an infinitely variable valve timing engine comes onto a production car...
You will not really have much of the valve train in this system. The valves will not be mechanically actuated. There will be solenoids on top of the valves, so mechanically it will make the system much simpler - no more timing belts, camshafts and cams, rocker arms etc. The complex bit will be calculating the appropriate amount of lift, duration and timing at each speed of the engine, in other words the software which will be an all new thing for the designers. Lotus already has prototypes up and running.
Just did a google and got the link for you guys:
Lotus Exige 265E gets Japanese debut - AutoblogGreen
Sparkie is offline   Reply With Quote
Old 20th October 2007, 08:37   #26
Default Partial load and VVA
Here is a quick explanation of the improvement the various VVAs bring to the low revs – partial load operation.
Take a look at the following plot (low revs and partial load in various valve train systems).
The plot is not accurate, nevertheless it provides the answer.
In all cases we start from the condition at point A (Top Dead Center, 1 Atm pressure inside the cylinder) and go to the condition at point B (1 At pressure).
The Red curve is the case of the conventional.
With almost closed throttle valve, the intake valve opens at TDC.
Soon the pressure drops to the pressure of the intake manifold.
As the piston is pulled downwards, the crankshaft has to overcome the vacuum into the intake manifold and into the cylinder.
The mixture enters slowly: there is neither significant speed nor turbulence nor swirl (the charge is like dead).
At BDC the intake valve closes and the compression of the charge starts.
The area between the suction part and the compression part of the red curve is the energy spent going from the condition A to the condition B.
The blue curve is the case of an engine with Lost Motion VVA.
There is no throttle valve, so the pressure before the intake valve is 1 Atm.
The opening of the intake valve at TDC does not change significantly the pressure.
As the piston moves downwards, the pressure drops and air/mixture enters into the cylinder through the small passage between the valve and the valve seat.
The high speed at the passage makes the mixture homogenous. The turbulence and swirl into the cylinder are high.
Very soon the intake valve closes. From that volume to the BDC and back to that volume, the total energy from/to the crankshaft is (nearly) zero.
A side effect of the process is that there is much time, from the closing of the intake valve to the BDC and then to TDC, to slow down the charge motion. This was a serious problem for the first Lost Motion VVAs (check the web for the SAE technical paper 2000-01-1221 for Delphi Automotive systems VVA).
The green curve is the case of an engine with Constant Duration VVA.
There is no throttle, so the pressure before the intake valve is 1 Atm.
As the piston moves downwards, the pressure drops and air/mixture enters into the cylinder through the small (significantly smaller than in the Lost Motion VVA) passage between the valve and the valve seat.
The extreme speed at the passage makes mixture homogenous. The turbulence and swirl into the cylinder is strong. The suction process continues until the intake valve closes at BDC, leaving short time to the charge to settle down before the spark at the end of the compression.
The cyan curve is the case of a VVA engine equipped with the Pattakon Electromagnetic Idle Valve.
The VVA keeps closed the normal intake valves.
There is no throttle, so the pressure before the Electromagnetic Idle Valve is 1 Atm.
As the piston moves downwards, the pressure drops but there is no induction of air/mixture because the Electromagnetic Idle Valve is kept closed. The piston pass the BDC. The vacuum into the cylinder is strong and “pulls” the piston upwards to the TDC (returning the energy absorbed for the downwards motion). The piston moves upwards and after the middle stroke the Electromagnetic Idle Valve opens for a few degrees, allowing air/mixture to enter the cylinder at high speed / turbulence /swirl, and then the electromagnetic Idle Valve closes. The motion of the charge have no time to “die” until the spark ignition occurs at the end of the compression.
The area between the suction part and the compression part of each curve (red, blue, green and cyan) is proportional to the energy spent to go from the condition A to the condition B.
As you see, in the case of the conventional engine the percentage of the generated on the piston (during expansion cycle) energy that is consumed to overcome the pumping loss is significant and, furthermore, it increases rapidly as the load gets lighter.
For a specific amount of power output, the VVA engine needs not to pass from the condition B, but from a condition C (representing by an intermediate point in the line interval A-B). This is because the additional pumping loss of the conventional, in case of the VVA engines is added to the energy delivered by the crankshaft. This way the difference between conventional and VVAs increase further.
I hope you understand now the difference (in energy consumption) of “the throttling exactly on the intake valves” from “the conventional throttling”.
You can find more at Pattakon Greece
Manolis Pattakos
manolis is offline   Reply With Quote
Old 20th October 2007, 08:52   #27
Default Acceleration and high speed with pattakon VVAr
Here are a few graphs taken with Hondata’s s200 data logger.
The B16A2 engine has the roller version of pattakon VVA on intake and exhaust valves (full version). All logs were taken with “Open Loop”.
The video at http://www.pattakon.com/vvar/OnBoard/A1.MOV(4MB) corresponds to the following log files:
http://www.pattakon.com/tempman/A1MOV.PNG and the http://www.pattakon.com/tempman/A1MOV.pdf
This data logging was one of the first, with the engine still having the original valve springs on it, and the Injection / Ignition maps finishing at 1 Bar.
The http://www.pattakon.com/tempman/no70.PNG , the
http://www.pattakon.com/tempman/no70.pdf and the http://www.pattakon.com/tempman/no70Analysis.pdf is another indicative data logging.
The egg shape Toda valve springs were installed. The columns from B11 to B16 of Hondata’s system (typically used for turbo applications) are used in Injection and Ignition tables (the ECU does not care if there is turbo or not).
The no70Analysis.pdf file, is an Analysis of the data.
The blue curve is the lambda value times the injection duration value, i.e. it is the quantity, per cycle, of air that is handled by the engine. At a first approach, the blue curve gives the form of the torque curve.
The red curve is the value of the blue curve times the revs (horizontal axis). At a first approach the red curve gives the form of the power curve.
The cyan curve is the MAP sensor. It gives an idea of how much the gas pedal was pressed at the specific revs.
The http://www.pattakon.com/tempman/ja21.PNG , the
http://www.pattakon.com/tempman/ja21.pdf and the http://www.pattakon.com/tempman/ja21Analysis.pdf is another indicative data logging.
The car moves slowly with 3rd gear at a steep uphill road.
In the ja21Analysis.pdf file the blue curve is the lambda value times the injection duration. This curve simply says that the engine at 750 rpm can handle per cycle some 130 units of air quantity, when the same engine at medium and high revs can handle some 150 units of air quantity.
The red and cyan curves are as in the no70 graphs.
The http://www.pattakon.com/tempman/de96.PNG , and the
http://www.pattakon.com/tempman/de96.pdf is another indicative data logging.
The car accelerates at an uphill road (the same as in the no70 logs).
Manolis Pattakos
Old 23rd April 2009, 11:41   #28
I have been following the VVT thread with great interest. You may find it interesting to Google "helical camshaft". There is a website (with short videos) about the helical camshaft and a Wikipedia article (and discussion page). This is a new development in variable valve timing. The system is reported to be able to produce a continuous (stepless) range of valve opening durations from about average for a normal road use car to (typically) about 100 crankshaft degrees above this - although it is claimed that in special cases that the duration can be so long that the opening flank of the lobe reaches the closing lobe. This means no base circle at all (or a duration of 720 degrees). All the duration change is at maximum valve lift. When used in a performance sense the HC has enough duration to suit shopping car to F1. When used for economy it allows engine control by LIVC - and reported fuel savings of 40% at idle. And both functions can be mixed in the one engine. I have been watching HC progress for a while now through magazine articles etc. and I can't see any blatant flaws in the idea - apart from it not being easy or cheap to make. Most ideas that pop up in connection with engines usually turn out to be flawed in some fatal way - but this looks OK to me. I would be interested to read what other people think of the HC.
Mighty Vlad. is offline   Reply With Quote
Old 30th June 2009, 13:47   #29
aaggoswami's Avatar
Thanked: 1,542 Times
There are basically three types of variable valve timing systems available.
1) One that can manage valve lift.
2) One that manages cam phasing.
3) One that manages both 1 and 2 listed above.
Honda's earlier were of variety 1. They were not able to process cam phasing, but managed valve lift, providing good top end power and that " kick " when high performance cam lobe was active.
VTEC was good for top end performance, but this is not what VVT from Toyota was designed for. Toyota was more interested in torque and bottom end + midrange.
There were some disadvantages though.
Now with modern technology, the computers can do a lot of stuff and its only when it detects very heavy load, it will make the necessary changes. This means if you are accelerating hard from 40 kmph, still the high power changes will be made. But if you are cruising at 100 kmph, still if no substantial demand is made on motor, it will not go for more fuel consuming high power settings.
Honda i-VTEC manages both phasing and lift. The latest Valvematic from Toyota is better than VVTi. BMW Valvetronic and Nissan VVEL ( developed with help from Delphi IIRC ) are all latest iterations of variable valve timing systems.
Hyundai Verna in India has very simple technology. At slow speeds the intake cam will be rotated in normal direction. But at high speeds, the rotation of intake cam will be reversed. This is not very efficient technology, but the power curve is observed to be more linear. I dont know how the latest itreation ( if at all it exists ) of Hyundai's variable valve timing works.
What really surprises me is that even Suzuki has VVT that is pretty meaningless. With VVT they can make just 107 horses from M16 block, and with same VVT they are able to put out 125 bhp in Swift Sport. This bump was attributed to VVT and different pistons from normal VVT enabled M16.
If anyone knows more, please put up :
a) How Suzuki VVT works.
b) How latest Hyundai Variable Valve timing system works.
aaggoswami is offline   Reply With Quote
Old 8th February 2010, 16:04   #30
shishir_bn's Avatar
Thanked: 108 Times
Default Variable Valve Timing discussion thread
MOD's, if this already exists then please merge accordingly.
We have heard a lot about the term VVT, VVTi and VVTLi, but not many of us really understand what it really mean?
What is VVT – Variable Valve Timing ?
Variable Valve Timing often abbreviated as VVT is a term used in Diesel, Gasoline and CNG Engines to define the timing for which valves are opened. The lift, duration or timing of the intake and the exhaust valves is controlled by this VVT system , in numerous combinations while the engine is operating. In two stroke engines, to get the same form of result a Power Valve system is used.
In normal non-VVT or non-VVTi engines, the valve timings are controlled by a set of cam shafts and belts mechanism. This mechanism will open and close the valves at a particular angle of crankshaft position and will close at a particular angle. In short, this system has no flexibility to change the angle. You can also say that its a hard-coded logic where the valves open at particular angle and close at particular angle at all engine speeds and load conditions. The disadvantage of this lack of flexibility is that engine does not perform at its best at all the engine speeds as optimum valve timings vary with engine speed and engine load.
In case of a VVT engine, the valve timings are controlled by a comparatively complex mechanism. In a VVT engine, the valve timings vary with the engine speed and engine load. This ensures that the valves open as per the need based of the engine speed and load. This small change in valve timings brings about a lot of improvement in engine performance, engine efficiency and engine power. In short, you can say that the role of the VVT system is to allow changes to the valve timing thus increasing the power and efficiency of the engine.
Note from Mod : Please do NOT cut-copy-paste entire articles from other sources. You may post a small excerpt with a "click here to read the full article" linky. In this case, the full article may be accessed over at carblogindia.
shishir_bn is offline   Reply With Quote
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
Does any one know G13BA or Esteem Carb ie 8 valve cam timing wildwheels Technical Stuff 5 20th January 2012 19:28
Variable Geometry Turbo - VGT NFS_Carbon Technical Stuff 7 1st December 2006 23:12
Variable Intake system and performance air filter shazikon Technical Stuff 1 23rd February 2006 20:27
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
