Old 11th February 2010, 17:08   #1
Default 1.3, OHC 2000 model - Steering issue
Hi fellas,
I am new to this forum. Feels good to be here.
Well I am having trouble with my OHC's steering - on and off that is.
Had put in new Good yr tyres ( stock ) this monsoon and after I had done so, a few days later my steering got stiffened. The stiffness was obviously felt due to the Power steering. It lasted for a week or so and then it came back to normal???
And the same cycle continued during the monsoon for 3 - 4 times.
But now the car is running absolutely fine. i.e after the monsoon..
What would have triggered off the stiffness???
Last edited by GTO : 12th February 2010 at 10:03. Reason: READ our rules, no more than 2 smilies per post allowed
555@speed is offline   Reply With Quote
Old 16th February 2010, 12:56   #2
sushrutha's Avatar
Thanked: 325 Times
Check your steering damper.
If it's not adjusted properly, sometimes steering becomes tight.
Old 16th February 2010, 15:26   #3
honda3938's Avatar
Where is the steering damper located in OHC. Can we adjust the steering gearbox in OHC.
honda3938 is offline   Reply With Quote
Old 16th February 2010, 20:20   #4
Shan2nu's Avatar
Thanked: 89 Times
I think its a common thing with the OHC. Even i find that the steering to be a bit stiff when its raining or very cold outside, but on a hot afternoon (or once the car has really warmed up), the steering is butter smooth and gives very good feedback.
Same thing goes for the suspension. Maybe dry heat does something to the fluid.
Shan2nu
Old 16th February 2010, 23:06   #5
jav
the same thing happens in my indica as well, i guess the water and mud combo makes the ball joints/moving parts stiff, a good pressure wash later and everything is smooth again
jav is offline   Reply With Quote
Old 17th February 2010, 11:52   #6
@ Shan2nu - I agree with you buddy.......
It is something that I really get pissed off with, but I guess have to live with the same
Benz W210 Pre 2000 suspension vs post 2000 Mohnish Technical Stuff 2 21st January 2009 19:48
need some rubber for my 2000 OHC sankeerthreddy Tyre & Alloy wheel Section 53 6th March 2007 23:50
OHC Automatic 2000 bisabhi Sedans 10 8th April 2006 21:58
Ford Ikon 1.6 2000 model sid_lath The Indian Car Scene 16 20th May 2004 21:13
