Old 12th February 2010, 12:17   #1
Unhappy My maruti 800 has extra energy
My maruti 800 2002 model, standard. sometimes, like, wants to surge ahead, with a wrooom, wrooom sound. mostly this happens when i am travelling back home from office and sometimes early mornings. I have noticed this tendency once the car is started after being parked for quiet some time.
this occurrence is maybe twice thrice a month.
The surge is really funny.
any technical explanation's, friends.
11mahesh11 is offline   Reply With Quote
Old 12th February 2010, 21:03   #2
vigsom's Avatar
Thanked: 604 Times
It appears that your rpm does not remain stable;get your throttle body serviced
Old 12th February 2010, 21:26   #3
Is you M800 Carb one?? If yes it can be the issue with the spring which is on the mixing screw. It can also be faulty accelerator cable which is not coming back as it should.
Does this happen only while running or the RPM are unstable while idliing? Does your car have AC? Which fuel?
SamtheLeo is offline   Reply With Quote
Old 12th February 2010, 21:44   #4
samsag12's Avatar
Thanked: 206 Times
Check for the accelerator cable joint near the paddle. Little amount of rust can cause this. Very risky in bumper to bumper situations as you tend to brake to avoid touching the car in front and the throttle revs the engine upon itself causing accidental movement of car.
Old 13th February 2010, 01:14   #5
vivekiny2k's Avatar
Thanked: 184 Times
Is your Maruti manufactured by Toyota?
agree with others, culprit must be your accelerator cable or related mechanism.
vivekiny2k is offline   Reply With Quote
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Maruti Suzuki to pay Rs. 150 crore extra as additional excise duty Aditya The Indian Car Scene 0 20th October 2014 18:10
Maruti Launches A-Star Aktiv (limited ed with extra fittings) kmadhok The Indian Car Scene 37 4th January 2013 14:46
Soft Drinks, no extra service but extra charge. bblost Shifting gears 58 21st February 2011 16:03
How has my 1.4 litre FIRE FIAT LINEA (F. Red) has lived the 5000 kms run? A report. omar1310 Test-Drives & Initial Ownership Reports 29 26th December 2009 13:15
