Old 16th February 2010, 19:09   #1
Default Issue with Santro rolling when parked in first gear
HI ,
My 7 month old Santro rolls when parked uphill in first gear if I dont use the parking brake .Does somebody know the reason for this .
Shashidhar.l is offline   Reply With Quote
Old 16th February 2010, 22:18   #2
jkdas's Avatar
Thanked: 1,436 Times
It rolls down just like that or when you give it a push? Always use handbrake when you park; slope or not! Start the car and then release the brake. Make this a habit.
Old 16th February 2010, 22:27   #3
jav
does the car roll continuously or stop and go ? AFAIK when i park my car in gear it does roll back a little then stops
jav is offline   Reply With Quote
Old 16th February 2010, 22:31   #4
vigsom's Avatar
Thanked: 609 Times
Originally Posted by Shashidhar.l View Post
HI ,
It should just roll back a foot or two and then stop;after all it is in gear.
Old 16th February 2010, 22:41   #5
Also how steep isthe climb??
To determine park this on a flat surface & engage 1st gear & push gently. Normally it will not roll. if it does not may be the slope is too steep. Use hand brake.
SamtheLeo is offline   Reply With Quote
Old 16th February 2010, 22:47   #6
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
if your vehicle is in gear, it should not roll, check if gear is engaged properly or else it must be in neutral
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 16th February 2010, 22:52   #7
planet_rocker's Avatar
Thanked: 368 Times
the front tyres skid and rear ones roll (without handbrake and 1st gear engaged) - aint you supposed to engage Reverse gear when you park on a slope with the car facing the top of the slope?
planet_rocker is offline   Reply With Quote
Old 16th February 2010, 22:56   #8
jav
nope the wheels would still skid if they are skidding in 1st gear, instead the car should face downhill with reverse engaged in really steep slopes
Old 16th February 2010, 23:10   #9
Jaggu's Avatar
Thanked: 8,694 Times
a) Use hand brake
b) How much of roll. Is it a small jerk and then stop or not at all holding?
c) What is this uphill? Major gradient? Vehicle facing which side?
Old 17th February 2010, 14:40   #10
I ususlly use the Hand brake , however when I don't, I see that the cars starts rolling when parked in 1st gear and also when I use Reverse gear !!!
The car is facing uphill and the gradient is not very steep .When I engege the 1st or reverse gear and turn off the engine in a gradient the car rolls back a bit then pauses slightly then rolls and pauses and then rolls again ...this stop- roll-stop-roll continues till I apply the handbrake !!!
Old 17th February 2010, 15:44   #11
Thanked: 198 Times
Please practice the use of hand brakes, whether uphill/downhill/ plain roads. A rolling car can cause accidents so don't forget to engage your hand brakes
tj123 is offline   Reply With Quote
Rolling Rolling Rolling... BB311 Introduce yourself 3 29th April 2016 16:20
First Gear : A Book for first-time Car Buyers in India (Download link Inside) GTO The Indian Car Scene 24 5th August 2013 15:58
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
India assembled BMW rolling out on March 29 tsk1979 The Indian Car Scene 32 5th April 2007 20:12
Baleno: Rolling noise what is the truth? javedbhaimumbai The Indian Car Scene 25 21st October 2005 03:44
