Old 17th February 2010, 08:25   #1
quicksilvr's Avatar
Default Dielectric grease - Where can I find some?
To start with, my Baleno had some weird jerking problem under acceleration. I knew it had to be electrical or fuel related. I checked the pump, it was good, I changed the fuel filter, still didn't fix the problem.
So before getting to the coils, I wanted to check the connectors. They were all quite dusty, probably even rusty to an extent. I took them all out, cleaned 'em and applied some dielectric grease, which I had at home, and plugged them back - and there you go - the wasn't missing a beat!! This was after countless, futile trips to MSM & local mechanics.
Anyway, another friend of mine has the same problem with his Wagon R. Since I had run out of dielectric grease, I went out to GP road, and to my surprise, I couldn't find a single shop carrying it!!!
Any idea where I could get my hands on them? Willing to order online from trusted sources!
quicksilvr is offline   Reply With Quote
Old 17th February 2010, 09:47   #2
aargee's Avatar
Thanked: 2,142 Times
Does one of these suit your needs?
1. Loctite Dielectric Grease - Full - Henkel
2. Loctite Dielectric Tune-Up Grease - Full - Henkel
You may want to talk to these guys for more info
Henkel India Ltd.
TPL House, First Floor, 3, Cenotaph Road, Teynampet
Chennai – 600 018
Phone: 044 24337350
BTW, just curious to know what was the brand that you've been using?
Old 17th February 2010, 17:27   #3
Raccoon's Avatar
Thanked: 105 Times
If you are unable to find it, can't you just use some petroleum jelly?
Old 19th February 2010, 09:07   #4
quicksilvr's Avatar
@aargee - It was Loctite, but I wasn't able to locate a dealer. Thanks for the the contact info.
@Raccoon - Vaseline might be able to do the job just as well, but I'm just a little worried that the it may get a bit runny in such high temp environments.
Old 20th February 2010, 17:47   #5
Raccoon's Avatar
Thanked: 105 Times
^^^Oops, you are right, it won't get just a bit runny, it might well get really runny. Btw, in case you do use it, try and avoid Vaselene. Its more prone to melting and is more expensive. Its fine for skin, but not for automotive use. Go for thicker, cheaper, small brand petroleum jelly.
Old 20th April 2016, 10:38   #6
dkaile's Avatar
Thanked: 4,463 Times
Default Re: Dielectric grease - Where can I find some?
Any local sourcing for getting good and economical Silicon Dielectric Grease and Anti Seize Compound (Aluminum/Brass)?
dkaile is offline   Reply With Quote
Life of Axle grease - When should we replace it? tsk1979 Technical Stuff 11 29th April 2014 12:00
Which car to buy ? Please help this new born grease monkey BmwAddict Luxury, Imports & Niche 26 21st June 2009 05:57
