Old 19th September 2005, 13:52   #1
abhi182's Avatar
Thanked: 202 Times
Angry Burnt Clutch Cover assembly?
HI,
A few months ago, there was am minor problem with the release bearing of my Corsa's clutch assembly...Whenevr I would depress the clutch, it would emit a mildly jarring noise....
I took the car to the Sundaram GM authorized service center in Chennai who disassembled the clutch assembly and replaced it for a total of 6000/- :-O
Saturday night., I was driving down the ECR when all of a sudden, the gearshift refused to work....The gears would not budhe at all when I tried to change them with the engin running...the gears would however engage when the engine was switched off.....
So I took the Car to Sundaram where they tell me that the Clutch Cover asembly has burnt out completely.....
A few quick googles revelaed that the only two causes for this could be wear (highly improbable for a 30K run car) or incorrect assembly which would lead to this :
" When installing the clutch cover assembly, the cover assembly was not tightened in the proper sequence. When one retainer bolt is over tightened, the pressure applied bends the sheet metal of the cover hat assembly. When the hat is bent, the rings that the diaphragm rotate on are not parallel to the plane of rotation "
Please suggest what should I do.....I am more than highly p&%$ed off at the Sundaram workshop.....
Anyway I can bring it to General Motor's notice?
abhi182 is offline   Reply With Quote
Old 19th September 2005, 14:01   #2
dadudeonfire's Avatar
you will have to change the whole clutch plate dude...and do not go to any mechanic ...its always better going to authorised dealerz...i felt something wrong with my clutch too...after modifyin my car...im gettting some strange sound whenevr i move my steering...showed it to rio he said its my power steering problem....anyways...3-4 days back..was driving my car..whenever aftrer applyin i was releasing the clutch..it wasnt coming back to its place properly...i mean it was coming slowly..as if there is some dirty heavy load on the clutch...every 10th time this thing was happening...i got scared because already after i have 1 problem and now other problem..and was confused because i feel that the day your car gives u 1 problem...you should service it completely or it will screw you for the rest of itz life...couldnt take it to the showroom because it was visarjan day...so thought ill go on monday...went for a small drive...hahahah realised that there was a chewing cum on the mat and because of that whenever i was pressing the clutch it was getting stuck to the mat and coming up slowly...hehehe....
dadudeonfire is offline   Reply With Quote
Old 19th September 2005, 15:05   #3
abhi182's Avatar
Thanked: 202 Times
Umm..^^^ think u rmissing the point....
The last time when I got the release bearing changed, itwas at an authorized service center (Sundaram)...What I find surprising is after when they opened the Clutch assembly at 30K and the pressure plate was fine then, how did it go completely bad in a span of just 5000kms?
All I can attribute it t bad worlmanship the last time around....
Old 19th September 2005, 15:49   #4
tsk1979's Avatar
Thanked: 16,422 Times
Workshop repairs usually have a 6 month warranty. If your assembly has burnt during that period, then sundaram has to replace it for free. If they want to charge you for it contact GM and list your case. You can also contact Autocar India, they can contact the manufacturer for you if they are uncooperative.
Old 20th September 2005, 10:24   #5
Domnic's Avatar
i kinda doubt the cover was burnt, the springs might have failed and preventing the clutch from engaging it or it was probably the plate. Open up the box again and inspect the clutch, make sure they replace it with an oe one and also replace the releaser bearing too. The plate centering should be perfect for ease of installation of gear box. Torque tighten the clutch fastners according to company spec and in the right sequence. ask them to give you the old plate its kinda strange for a plate to bun so fast! unless the company is upto something... and yes if it was replaced recently take it up to the managers and ask for a replacement as the work carried out was of no use.
cheers
Domnic is offline   Reply With Quote
Old 2nd December 2005, 18:39   #6
haljosgeo's Avatar
TVS is the worst services company India has seen, my family doctor has a Siena and the only woe he has is about the service they do. FIAT had Uno which was an awesome product, TVS screwed it up in Tamilnadu and Kerala, then came Palio which was a wholesome except for the mileage (you don't buu a 1.6 GTX for mileage anyway) and TVS were around doing what they do best, screwing things up. If only FIAT get's to learn the ropes from Maruti or Hyundai about setting about quality service centers, their after sales woes would be history, alas ......... I am still dreaming
haljosgeo is offline   Reply With Quote
MM550 Clutch Assembly sreerajunnithan 4x4 Technical 1 3rd December 2011 19:34
Which Clutch Assembly to buy for Maruti Zen 04 simply_sunny001 Modifications & Accessories 6 7th May 2008 19:15
Bullet Mag-wheels (size = 19") and 4-plate clutch assembly for sale wanderlustindia Shifting gears 0 27th December 2007 17:15
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
