Old 28th February 2010, 16:32   #1
vigsom's Avatar
Thanked: 604 Times
Default Weird Problem With Charging System
While returning the day before night,I realised that the battery warning light was coming on off and on.The car was on full Electrical load - ac,lights,ICE .This is a Versa 2003 BSII.
I also noticed that the horn was sounding weaker thannormal and lights were not that bright leading me to believe that there is a problem in charging.
Came home ,and shut the car off and turned they key on again - only the engine check light and the oil pressure light came on.Start the car and raise the rpm to approx 2500 when the battery warning would come on;release throttle and the light would go off.
Went to my trusted auto electrician the next morning(was scared that the battery would lose charge as the workshop was 11km away),but nothing happened.
Normally one would believe this to be a problem in the alternator but it turned out to be a bad coupler on the main charging cable.The coupler would not decouple and eventually the cable ends had to be soldered using hi temperature solder.
All was well after this - the battery light came on with ignition on,went off after engine fired,and the voltage across battery was 13.7V with engine running - a sign that the battery had run down a bit.
I was told that this is a common problem and M800 is notorious for this.
Some pics of the coupler.You can see the broken white portion - the coupler saw sparking and the complete inside has disintegrated
Lessons Learnt:
  1. Be watchful always - for tell tale signs on the dashboard
  2. Keep learning and sharing.
Old 28th February 2010, 17:20   #2
Rehaan's Avatar
Thanked: 25,042 Times
Interesting!
This would not have been high on the list of guesses for what was causing your problem had i had to take a shot at it.
Originally Posted by vigsom View Post
[*]Keep learning and sharing.
Following in that tradition - does your camera have a macro mode? In your pics it seems to be focussing on the background.
cya
R
Old 28th February 2010, 17:33   #3
vigsom's Avatar
Thanked: 604 Times
This is a Canon Powershot A520(an old 4MP one);I have not been able to take good closeups;don't know why
Old 28th February 2010, 18:54   #4
Rehaan's Avatar
Default Forgive the OT
Press the macro button (the flower should be shown on the screen). The camera will then focus on on objects that are very close, but will not focus on objects further than about 10-20cm.
Source : Link
Do put up some new pics of you can.
Old 28th February 2010, 20:44   #5
Thanked: 2,404 Times
While returning the day before night,I realised that the battery warning light was coming on off and on....
As you have mentioned, a fairly common problem. However,the Ign telltale should come on initially. Am wondering why it did not in your case. Also, the glowing of the Ign. telltale when the engine is revved should be fairly faint. Was it so in your case?
Sutripta
Old 28th February 2010, 21:39   #6
vigsom's Avatar
Thanked: 604 Times
What I first observed was the battery warning light come on faintly when the rev went up and go off when I shifted to the next higher gear.
When I tried the rev at home,the light was on in full splendour when the car was revved to 2500rpm plus.It would go off at approx 2000 rpm
Rehaan, thanks for the tip;will try to get clearer pics tomorrow(after holifying)
Old 1st March 2010, 10:14   #7
vigsom's Avatar
Thanked: 604 Times
Happy Holi Guys.
am posting a few more,hopefully clearer pics
The Coupler - there was some foam on the yellow portion,possibly to keep it insulated,the foam had disintergrated
Old 1st March 2010, 12:20   #8
vigsom's Avatar
Thanked: 604 Times
some more pics - see how the inside of the coupler has got heated up and discoloured,probably due to sparking
Old 1st March 2010, 22:17   #9
I still can't reconcile these two symptoms (Ign. telltale not coming on initially, and then coming on fully bright when engine is revved) with the bad coupler. Anyone with any theories?
Sutripta
Weird issue with my audio system octy9833 In-Car Entertainment 7 28th August 2012 14:07
Honda Unicorn- Charging Problem--Help!! tj123 Motorbikes 11 7th January 2010 17:36
Weird problem...Palio Iknowthisguy Technical Stuff 16 31st August 2006 08:58
Weird computer bootup problem adya33 Gadgets, Computers & Software 7 28th March 2006 23:50
