Old 1st March 2010, 11:53   #1
MileCruncher's Avatar
Thanked: 357 Times
Default Engine Overhaul & Emissions
I got the engine of my FIAT Uno 1.2 Petrol just overhauled as after 1.07 L Kms, it had started consuming oil in 2 cylinders. Even while it was consuming oil, the emissions as per PUC Certificate was way below the limit. But I got the PUC done yesterday and SPM and CO has increased considerably. I think my Catcon is working perfectly fine as if I hold my hand near the exhaust, I do get water vapour.
So what can be the reason for increase in emissions?
MileCruncher is offline   Reply With Quote
Old 1st March 2010, 14:56   #2
Thanked: 660 Times
It may be many number of reasons. common is improper tuning.
Also how much has it run after the overhaul.
Old 1st March 2010, 17:06   #3
Thanked: 357 Times
I don't think its improper tuning as its an SPFI with ECM and everything is stock and all sensors are perfectly working.
And after rebuild its done about 2k Kms.
Old 1st March 2010, 17:34   #4
SS-Traveller's Avatar
Thanked: 11,626 Times
Originally Posted by MileCruncher View Post
...got the PUC done yesterday and SPM and CO has increased considerably.
Increased, but are they within permissible limits? Check your FE and spark plug colour to verify if the engine is running rich. Does the engine hunt/knock/choke when cold or when accelerated hard?
Too many reasons for an increase in emissions. Might be as simple as an ECM setting or faulty injector issue (or even a leaky exhaust before the overhaul), or it might be as bad as a poorly seated exhaust valve.
Old 1st March 2010, 18:44   #5
Thanked: 357 Times
Yes well within limits. The CO limit for 2000 Make petrol cars is 3.00% and mine is giving 2.16%. Previously it used to hover around 0.5-0.6% . (Need to see the exact figures for SPM)
I'm getting a FE of about 11KMPL which is slightly better than before and the Spark Plugs are biscuit colour. No engine hunting/knocking or chocking, Has become much more free revving than before. While overhauling, the valve seating has been lapped and something minor done to the head also to improve slight performance.
Old 1st March 2010, 20:10   #6
vigsom's Avatar
Thanked: 603 Times
Spark Plugs are biscuit colour. No engine hunting/knocking or chocking, .
that's healthy - It could be just that you need some fine tuning
Old 2nd March 2010, 00:06   #7
Yes well within limits. ...mine is giving 2.16%.
...FE of about 11KMPL which is slightly better than before and the Spark Plugs are biscuit colour. No engine hunting/knocking or chocking, Has become much more free revving than before. While overhauling, the valve seating has been lapped and something minor done to the head also to improve slight performance.
Forget about the issue and go to sleep! Check PUC again after 3 months, keep an eye on the FE, and the next time ensure that you've completed a long high speed drive before checking. And switch off that AC at least 15 minutes before checking.
A fuel-efficient car is not usually a polluting car.
Happy driving!
BMW shares drop on report that X3 diesel's emissions exceeded EU limit TheDoctor The International Automotive Scene 5 26th September 2015 16:44
Advice & guidance needed for engine overhaul- Yamaha Libero 2003 deetee Motorbikes 1 20th January 2012 17:24
TTXGP - Joint Indian-English company Agni blitzes in first clean emissions Grand Prix ksreddy Int'l Motorsport 2 13th June 2009 14:43
Mini's Success: New Zero-Emissions Drivetrain! K-S-A The International Automotive Scene 5 11th August 2008 07:48
