Old 4th March 2010, 12:00   #1
Thanked: 187 Times
Default TDCI or Multijet - Which is technically superior?
With Figo all set to make a big splash with VFM pricing, iam sure a lot of new diesel car customers will have the daunting task of choosing between the TDCI and the plethora of Multijet offerings.
My query to this forum is - Which engine is better, technically? I know an engine does not maketh a car.
Refinement, turbo lag, fuel efficiency, long-term cost of ownership (upkeep), etc can be points of consideration/discussion.
This is not a poll to decide a winner. Just a thread to discuss the relative merits/demerits of these engines from owner's perspective.
Thanks,
WR
WindRide is offline   Reply With Quote
Old 4th March 2010, 12:18   #2
Blue Thunder's Avatar
Thanked: 335 Times
Hope you are aware that the TDCi is Ford's name for it's range of Common Rail Turbo diesel engines, while MultiJet is a term used on the Common Rail Turbo diesel engines from FIAT (initially FIAT used the term JTD).
So, both TDCi and MultiJet have something in common in technical terms : they are both Common-Rail Turbo-Diesel engines.
(CRDe is Mahindra's term for the same type of engine, while DICOR is Tata's term and Toyota's is D-4D).
http://en.wikipedia.org/wiki/Common_rail
Therefore, I dont understand the point in trying to compare TDCi and MultiJet, or just TDCi and Multijet ???
Blue Thunder is offline   Reply With Quote
Old 4th March 2010, 12:33   #3
Rotorhead's Avatar
Thanked: 21 Times
Common rail - Wikipedia, the free encyclopedia
Also add the hyundai CrDI to the list .
Rotorhead is offline   Reply With Quote
Old 4th March 2010, 12:36   #4
greenhorn's Avatar
Thanked: 1,519 Times
I guess he wants to compare the common rail implementations. Given that people have compared even between the various MJD's ( the SWIFT BS III vs Ritz BSIV vs punto/Indica MJD etc), the request sounds reasonable
Old 4th March 2010, 13:54   #5
The multijet and the TDci will retyrn almost similar fuel economy figures but the Tdci is devoid of any turbo lag which makes city driving easier compared to the multijet.
The multijet should be easier to maintain though since it is produced in more numbers compared to the tdci and so the spares should be priced lower than the Tdci.
shantyrocks is offline   Reply With Quote
Old 4th March 2010, 14:04   #6
Thanked: 237 Times
Second Generation Ford Ka uses Fiat Multijet Engines rebadged as Duratorque TDCi. This says that Multijet is better compared to Fords own implementation.
sushantr5 is offline   Reply With Quote
Old 4th March 2010, 14:07   #7
Thanked: 85 Times
Though both are Common Rail, the TDCi is a bit older compared to the MJD/JTD/QJD/DDiS.
Live To Jive is offline   Reply With Quote
Old 4th March 2010, 14:28   #8
Thanked: 545 Times
Even the diesels on Fusion/Fiesta are also called Duratorque. Are you sure what they use in Ka is different?
Guna is offline   Reply With Quote
Old 4th March 2010, 14:39   #9
Thanked: 34 Times
Ford Ka uses 1.3 Multijet. I am not sure whether it is so because MJD is better than Duratorque or not, but, as we all know, Ford Ka is a rebadged Fiat 500. It helps to contain the costs if they use the same engine across essentially the same platform.
deepakhon is offline   Reply With Quote
Old 4th March 2010, 14:40   #10
lloydofcochin's Avatar
Thanked: 180 Times
Ford Ka - Wikipedia, the free encyclopedia - This link confirms the same.
lloydofcochin is offline   Reply With Quote
Old 4th March 2010, 14:42   #11
Daewood's Avatar
Thanked: 223 Times
The multijet in Palio and Indica shudders when idle.
Is it the same case with TDci also?
is it an unavoidable thing in small diesel engines?
Daewood is offline   Reply With Quote
Old 4th March 2010, 15:18   #12
Thanked: 58 Times
In my opinion, I feel the Multijets are more fuel efficient and a pack more torque than the Ford developed TDCI. Not a guru on diesel engines, but someone please correct me if I am wrong on this one.
rjalihal is offline   Reply With Quote
Old 4th March 2010, 15:27   #13
DieselFan's Avatar
Thanked: 234 Times
Diesel engine clatter (higher sound emitted compared to Petrol) during idle is true for all Diesel engines irrespective of size or design. It is unavoidable. After a while of owning a Diesel car you would like hearing the same and feel something is missing in a petrol car.
DieselFan is offline   Reply With Quote
Old 4th March 2010, 16:02   #14
SPARKled's Avatar
Thanked: 407 Times
I guess only the VW group's Pump Deusse or PDI technology is slightly different to the CRDI technology. CRDI being better at insulating noise and vibrations. Experts your views please.
SPARKled is offline   Reply With Quote
Old 4th March 2010, 16:04   #15
mohandas's Avatar
Thanked: 27 Times
Ford Duratorq: It's from the school of old tech. It is non-inter-cooled 8V SOHC engine.
DDiS (QJD/MJD): It's from the school of new tech. It's inter-cooled 16v DOHC engine.
Technically, DDiS is miles ahead of Duratorq, a engine that comes from Nizam's Era (1998). Duratorq is basically Euro III compaiant engine, and by adding diesel particulate filter, it is made to be EuroIV compaiant. Duratorq is not going to see the EuroV days. That's why ford was compelled to take MJD in their Ford Ka.
Edit:
Just found that ford is selling this engine only in developing countries.
mohandas is offline   (1) Thanks Reply With Quote
Dealer quoting astronomical amount for technically correct IKON headlights!!. dhanushs Technical Stuff 32 10th January 2011 15:01
Ford Ikon TDCI or Fiat Palio Multijet SdX streetlife Sedans 70 13th December 2008 17:40
Is German Engineering THAT superior himanshugoswami The Indian Car Scene 36 26th March 2008 18:33
How superior is synthetic oil over the normal 15W oils ? maxbhp Technical Stuff 7 25th September 2006 18:04
