Old 11th March 2010, 20:09   #16
Thanked: 16 Times
Today, I left the car at THE famous service center at Garvepalaya, Hosur road for the whole day, and after getting the car back, car is still pulling to the left and now to add to that, now it feels like i have power steering disabled on the car :( To add to that, the steering wheel points to the right when going straight.
I am not clear why a service center which has technicians trained by the manufacturer would not be qualified enough to do the alignment work on a car compared to individual tyre shops.
Concerns with dedicated tyre alignments shops is that I had found they have tools that are not as good as service centers. For example, they put the jack at the wrong place and possibly damage the under body of the cars.
Also the customer service is too bad and they simply dont care. And you have to wait too long a time to get the work done. This is from my experience from a famous alignment center at JP nagar.
Either way I have learned an expensive lesson, but i found the JKs to be pretty good for my style of driving and never had any complaints, till now. Just recently for the past months i heard tyre squeal while cornering even at sedate speeds even around 70 kmph. Realising now, it might be something to do with the mis-alignment.
Please recommend any good independent tyre/wheel alignment centers around either Electronic city or Bannerghatta road area who are well equipped to do this kind of a job.
ramkris is offline   Reply With Quote
Old 11th March 2010, 20:51   #17
Thanked: 141 Times
@ ramkris: By looking at the tyre wear that is now time to replace them. Which is 'The Famous service centre' you are referring here - not sure.
From what you are mentioning about pulling to the left, definitely the wheel alignment issue there. But if you hadnt felt that before the recent service, then I would also suggest to check the lower arm (any recent underbody scraping / hitting the humps?) Lower arm bend/out of position could also give the tyre uneven wear - please note.
If you are not talking about Suraksha car care center here, please try it out, you can mention that you are from TBHP and get things easy and better then.
Hope that helps..
narayanang76 is offline   Reply With Quote
Old 11th March 2010, 21:08   #18
sdp1975's Avatar
Thanked: 972 Times
ramkris, please visit Madhus on Langford road. They have state of the art equipment for alignment. The steering wheel problem should also be corrected during alignment.
Madhus.com
Unfortunately, your tyres have to be replaced seeing the amount of wear in them.
Also, why don't you approach the service centre asking them to bear the replacement cost in part based on usage ? After all, if you have been getting your car regularly serviced from them, it's their responsibility to ensure that the alignment is taken care of and the tyres last their usual lifetime. Complaining to Maruti might also help.
sdp1975 is offline   Reply With Quote
Old 11th March 2010, 21:28   #19
Jaggu's Avatar
Thanked: 8,674 Times
Ask them to loosen the steering damper when doing alignment and that will sort out the tight steering. Better buy new tyres.
Old 11th March 2010, 21:28   #20
vinu99@gmail.co's Avatar
Thanked: 39 Times
Originally Posted by Nikhilb2008 View Post
It's definitely a wheel alignment issue. No question about it.
Did you get it done regularly or did oyu just ask the service guys to do it when you ghave it for service?
Even with a regular alignment interval of 5000 Kms, I had my Swift rear tires worn out in a similar fashion, but not as bad as these tires. I had to discard those at 26000 Kms. Few of the tire guys attributed it as a common issue with Swift rear tires. Coincidentally, front tires were displaying a uniform wear. Overall, I had not much hard feelings as I got less than 50 kms run MRF ZV2ks for 800 a piece from a brand new Swift which underwent a tire upgrade
vinu99@gmail.co is offline   Reply With Quote
Old 11th March 2010, 21:41   #21
Thanked: 16 Times
Rubbing salt in the wound, I tried to plug in the panel of my Eclipse 5030 HU after getting the car back from the service center and the display wont turn on, and no controls work but the cd will play. Another 15k down the drain apart from prospective tire change cost.
And by the way the service center I mentioned is RNS Hosur road. Didnt want to mention it if they were able to resolve the issue.
Old 11th March 2010, 22:04   #22
Jaggu's Avatar
Check if the terminals of the HU and face plate are aok. Use a fine tweezer or pin to set it right, but be very careful.
Old 11th March 2010, 23:06   #23
Thanked: 706 Times
Don't think that training from manufacturer would involve detailed instructions about wheel alignment. Secondly, service technicians would be more interested in learning about car repair details rather than wheel alignment. Sorry for going off topic.
From my limited knowledge, to carry out wheel alignment, one need not put car chassis on jack. Sensors get attached to wheel to read alignment data.
Please visit competent tyre shop as suggested in earlier posts.
It's very much likely that HU faceplate hasn't been placed correctly. Remove it & connect it properly again. It should work if no contacts have been broken in previous removal/attach process.
sukiwa is offline   Reply With Quote
Old 12th March 2010, 10:35   #24
VTEC_Rocks's Avatar
I'd recommend Vijay's Wheel Alignment near Sajanrao Circle. They do a good job, or you could get it done in Srinidi Agencies in Adugodi. He does a fair job too.
VTEC_Rocks is offline   Reply With Quote
Old 12th March 2010, 10:38   #25
Thanked: 16 Times
[quote=sukiwa;1778358
It's very much likely that HU faceplate hasn't been placed correctly. Remove it & connect it properly again. It should work if no contacts have been broken in previous removal/attach process.[/QUOTE]
When a wheel alignment is done, we generally go for tyre rotation and that is when I was referring to jack being used.
I know its OT but regarding the HU, there definitely seems to be a problem with the HU. I had done all basic checks: checking if it is inserted properly, try to clean the contact points on both the HU and faceplate etc., to no avail. I will check the wiring and the fuse later to see if there is any loose connection. Maybe its time to open a new thread for new HU recommendations in the ICE section.
Old 12th March 2010, 23:12   #26
Thanked: 660 Times
Its an alignment issue.
I recall you have run 20000 +kms. in this course of time you should have rotated atleast 4 times. have you done that.?
HELP! Uneven rear tyre wear in Wagon-R ravi@64bhp Tyre & Alloy wheel Section 13 4th July 2016 17:02
Uneven Tyre Wear? IMP Technical Stuff 31 4th June 2012 18:02
Need Help : Excessive tire wear problem in Swift VXI Jan 06 D1ISTHE1 Tyre & Alloy wheel Section 21 9th November 2007 00:01
Some questions about tyre wear devarshi84 Tyre & Alloy wheel Section 68 5th April 2007 15:56
Uneven Tyre wear!? - Goodyear GSD2 Eagle F1 anarchist Tyre & Alloy wheel Section 4 10th March 2006 13:00
