Old 16th March 2010, 09:52   #16
aargee's Avatar
Thanked: 2,143 Times
So what happened? Did it solve the vibration issues?
Old 16th March 2010, 11:21   #17
krazydriver84's Avatar
Thanked: 42 Times
Hey Guys,
Got the Balancing and the Wheel Alignment done, but haven't been able to test it at high speeds yet.
Will do it in today in the evening and will revert back to you with the findings.
Keeping my fingers crossed, that it will have solved the problem.
krazydriver84 is offline   Reply With Quote
Old 16th March 2010, 12:39   #18
sumeethaldankar's Avatar
Thanked: 1,159 Times
The alignment guy would have been able to clarify if the wheel was out if the wheels were imbalanced.Did he mention anything about the same when you went in for the balancing .Anyways let's hope you get the desired results.
sumeethaldankar is online now   Reply With Quote
Old 16th March 2010, 13:53   #19
Thanked: 42 Times
The Camber was a bit out in the RHS.
As for the balancing of the wheels. A-OK
a minor weight of 5gms was added on to the Right Front wheel.
Old 17th March 2010, 10:39   #20
Thanked: 42 Times
So guys, Yesterday evening I was able to test the car out and the vibrations have disappeared.
Thanks Guys.
Am almost happy now, not totally coz I feel that the car is suddenly losing power to pull out. Recommendations guys?
Old 17th March 2010, 10:47   #21
aargee's Avatar
Good.
If its at those crazy speed, then its perfectly fine
On a serious front, can you elaborate "losing power to pull out" more?
Old 17th March 2010, 10:50   #22
Thanked: 42 Times
Good.
No not at those crazy speeds.
Losing power- I mean is that the car at 3rd gear is doing easy 40-50, but sometimes I need to shift to 2nd because I can feel the RPM dropping.
Old 17th March 2010, 11:53   #23
aargee's Avatar
Only at 3rd gear or all the gears & their max rev limits? Is it something like you're trying to overrev & you lose the torque? Gosh!!! 3rd & 50? I shift to 4th when my WagonR is in 40.
Old 17th March 2010, 12:11   #24
prince_pervez's Avatar
Thanked: 34 Times
Great thread. My zen also has vibrations after 80 kmph. So much so that nearing 100 the whole dash vibrates. Will go to Nikhil's shop sooner or later.
prince_pervez is offline   Reply With Quote
Old 17th March 2010, 12:37   #25
Thanked: 42 Times
Am not even gonna tell you at what speeds I shift to 4th.
Unable to tell you rev limits, as I don't have a rev meter. however, the loss of power is being felt on all gears. Do you think its due to the Clutch?
You should. It will improve the car's handling big time.
Old 17th March 2010, 13:23   #26
Bumble Beast's Avatar
Yes, It is your clutch. How many times do I have to tell you? Dont you remember the same thing happened to my car?
Bumble Beast is offline   Reply With Quote
Old 17th March 2010, 13:35   #27
Thanked: 13 Times
Gurus,
Need advice, My car - M800 has suddenly started vibrating at speeds of 120Kmph, earlier the car used to do constant 135Kmph easily without any vibrations.
Vibrations at 120 Kph ; mine starts vibrating as soon as the speedometer needle touches 90; haven't dared to do beyond that.
How much did the whole suspension change cost you?
I got my M800's done a couple of months ago at a MASS and it cost me around 7k.
Originally Posted by ElantraGT View Post
In case of wheels locking up, there is nothing much you can do as 800 brakes tend to lock up when you stand on the brakes. So its advisable to pump your breaks just to have some steering control during emergency situations.
That's so true, I happened to be in an emergency situation yesterday when this Indica driver, while talking over his cell phone, swerved into my lane, pulled the brakes and stopped, all in no time. I was doing around 50~60 kph and did not have the time and space to pump the brakes. Consequence, I stood on the brakes, the wheels locked up and I ended up hitting the Indica with quite a thud. I shall be driving with a deformed hood and malfunctioning horn (courtesy that insane driver) until the coming weekend
sheetumanu is offline   Reply With Quote
Old 17th March 2010, 14:01   #28
Thanked: 42 Times
Yeah, I kinda considered that, but am considering if anything else is on the wear and tear mode to lead to such a power drop.
Old 17th March 2010, 21:22   #29
Can you post a break up of parts cost for the suspension o/h.
thanks
Old 18th March 2010, 10:18   #30
Thanked: 13 Times
thanks
I'd need to hunt through my drawers for the invoice; would check and let you know.
Taking cars to high speeds Surprise Shifting gears 32 16th July 2007 23:56
Hatches and high speeds madan80 Technical Stuff 31 4th April 2007 19:32
Periodic noise at high speeds (Innova) oldmobile Street Experiences 0 11th September 2006 15:53
No power assistance from EPS at high speeds - Why ? mithun Technical Stuff 15 25th August 2006 23:00
Which is better ?AC ON or Windows rolled down in high speeds prince1a Technical Stuff 19 18th June 2006 11:54
