Old 19th March 2010, 16:55   #16
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by krazydriver84 View Post
Hi Sutripta,
Thanks for confirming my suspicions.
The reason I had this suspicion, was times when the lights used to go bright, I used to feel a slight drop in power of the car, and when the lights used to return to normal, I would feel the car surge a bit. Although these lasted a few seconds, I could still feel them under me.
However, taking everybody's advice, am gonna get the following work done this weekend:
- get the brakes checked for any jammin. (Precautionary check)
- Get the voltage regulator of the alternator checked and replaced if necessary. (top most priority)
- also get the compression of the rings checked (I highly doubt this)
- Get the clutch checked (Top most priority)
Any more advice.
Add plugs to the list as well
speedsatya is offline   Reply With Quote
Bad Roads Lead To Good Destinations! aviorp Travelogues 79 13th May 2014 20:37
Does leakage of AC-gas lead to death? (2nd time 3 dead in Santro(Carbon Monoxide)) GTS Technical Stuff 30 17th November 2010 19:18
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
