Old 17th March 2010, 15:21   #1
Default Bubbling Battery
Hi all,
I need some help and advice.
The problem : I have a Jan 2006, Indica turbo. 36000 km done. The problem is that the air-con blower goes into 'turbo' blow mode in random spurts, the bulbs fuse in 30 to 45 days, and there are bubbles around the battery, also corrosion marks around the battery area caused due to spraying electrolyte from the battery.
I though it was the alternator playing up, But both Lucas and tata service have ruled it out and said the alternator is fine. Full load charging is 14 approx, but rock steady. The electrolyte level was checked and reduced to half, (not that it was over filled) yet the battery bubbles.
Where could the problem be? and what could it be? The battery is OEM exide, I have 90/100 philips bulbs with minda relays and cutouts. Also I hear a high pitched whine once I switch off the engine, which dies down in a couple of seconds.
Any help will be appreciated.
Thanks and regards
Shiv
clix22 is offline   Reply With Quote
Old 17th March 2010, 15:32   #2
Jaggu's Avatar
Thanked: 7,478 Times
Looks to me a case of battery getting overcharged, get the regulator function of alternator doubly checked for both voltage and current.
Old 17th March 2010, 15:52   #3
sgiitk's Avatar
Thanked: 3,759 Times
Whatever the fellows may say, but the problem is definitely overcharging as has been rightly pointed out. Check out the wiring as well, esp. for a bad ground.
Old 17th March 2010, 21:58   #4
Thanked: 2,072 Times
Strange. I just replied in another thread on a similar issue.
You have an intermittent overcharging issue. Check all connections, esp alternator/ voltage regulator grounds. If all OK, replace the voltage regulator.
I thought this problem had been sorted out.
Sutripta
Old 18th March 2010, 17:47   #5
gomzi's Avatar
Thanked: 125 Times
Strange, I had a similar problem in my Indigo Tdi a few days ago. It was coupled with problems like yours, ac and lights behaving intermittently and battery fluid spilling out.
Took it to a local mechanic and he diagnosed it to be a problem with the alternator cutoff. That was replaced and the car has been working fine for the last couple of days.
gomzi is offline   Reply With Quote
Old 18th March 2010, 22:28   #6
Awaiting Email Confirmation
Thanked: 317 Times
Default Check the soldering.
I faced a similar problem in my Junkindica due to the use of 130/90 Philips rallye bulbs. The soldering pertaining to the voltage regulator came loose or rather dried out resulting in intermittent high voltage and consequent high amperage. Disassemble the alternator and ask the electronics guy to check for dry solder joints. Look up the net for dry solder joints and you will get my point.
drpullockaran is offline   Reply With Quote
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 12 25th November 2010 15:29
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
