Old 18th March 2010, 19:07   #1
Thanked: 7 Times
Default Santro Reverse light permanently on
May be it is because of the bumpy and undulating roads of Ranikhet and aournd (that I visited couple of days back), the reverse parking light of my Santro car is now permanently on. It seems the problem disappeared a few times for very short duration but mostly it remains on.
I would be taking it to workshop on weekends but I am curious to know if this problem is with the reverse parking light switch or is it because of some loose connection. Also, where exactly is this switch located? Maybe I can do some preliminary check myself.
Response highly appreciated.
Thanks.
ms_rana is offline   Reply With Quote
Old 18th March 2010, 19:26   #2
nick17s's Avatar
Thanked: 93 Times
Hi Rana Ji, I had the same issue with my Maruti..
Go to the car's electrician, and ask him to check 2 things:
1. Fuse box (some fuse might be blown up).., if it is fine then,
2. Reverse light switch (for that you got to open the bonet)..a new switch would come for around Rs. 200-250..
In my case it worked, hope that it will help you too..
nick17s is offline   Reply With Quote
Handbrake indicator permanently glowing SDP Technical Stuff 39 9th July 2018 18:15
Underbody Rust - Is it permanently fixable? greenhorn Technical Stuff 29 11th September 2015 11:51
Do all Tata cars 'age' permanently? greenhorn Technical Stuff 32 8th September 2012 01:19
Single Reverse Light X-Machine Modifications & Accessories 5 12th August 2007 10:41
Cool blue light's of my santro...!!! toy car Modifications & Accessories 28 9th May 2006 20:27
