Old 24th March 2010, 18:04   #16
driverace's Avatar
Thanked: 164 Times
@aargie
desmo valve system, operates with solenoids: as in electronic signal actuates the valves. this eliminates heavy cams-components,(considerable weights! in lightweight engines..)
plus, gives flexibility to have variable timing
Originally Posted by driverace View Post
@aargie
and lift, at any/all rpms, of all individual valve sets, independant of others!
I think, that is the dividing line.
@one-out-of-multiple cylinders firing at idle, umm, I remember reading this, that in V12, in some eco mode, only 4pots fire, while the others dont!
(sorry, I do not recall the source, though)
My thinking on the matter is, that if we keep the inlet nad exhaust valves of non-powering cylinders open in the case suggested by you, we can have the least possible resistance from the non-powering cylinders.
If we are missing/overlooking some things here, experts, please shed some light!
Care.
Ace.
Last edited by Rehaan : 26th March 2010 at 14:35. Reason: Merged on request. FYI - its okay if you make consecutive posts >20mins apart :)
driverace is offline   Reply With Quote
Old 26th March 2010, 10:06   #17
PhiGolden's Avatar
Thanked: 25 Times
@aargie
I do not think Desmo operates with solenoids. It uses an extra rocker arm to push the valve close rather than a spring. It seems the springs can lag at high speeds and the valve can remain partially open even when the piston is at TDC.
PhiGolden is offline   Reply With Quote
Old 26th March 2010, 11:01   #18
aargee's Avatar
Thanked: 2,143 Times
Strongly agree with you Golden;
@driverace - Here's my source to show you buddy - Desmo Valve Animation
PS - My handle is aargee & not aargie
Old 26th March 2010, 16:44   #19
Shan2nu's Avatar
Thanked: 89 Times
Wow, desmo valve system is neat. No need to worry about spring rating, valve float etc. The bottom arm will make sure the valve returns back on time.
But are those rocker arms adjustable to cams with higher lift or vvt cams?
Shan2nu
Old 31st March 2010, 11:29   #20
driverace's Avatar
Thanked: 164 Times
Default some error.
Yes, I actually read about those more later.
I was confusing them with this
source:
::: Automotive Control Lab :::
replacing the Hydraulic system with electrically actuated one (electro-magnetic in nature)
thank you for the animation!
My Bad.
Sorry aargee ~ !
Do Have a look at what I was talking about. (wrongly referring it to as desmo valves)
Camless Engines Promise Greater Efficency - Fuel Economy - Jalopnik
Doing the 6S engine on desmos seems tough too!
Shan2nu
We wll not need to worry about any cam profile/ or no need to change the cam profile for low/high speed gains !
the solenoids can be adjusted with simple programs to do so.
perhaps we can assign some non-linear relation with rpms for the lift & duration of the lift.
Sorry for the goof-up.
Care.
Ace.
2T Oil for Two Strokes becoming hard to source? anjan_c2007 Motorbikes 12 24th June 2017 19:45
Honda patents engine with variable piston strokes (EXlink) volkman10 Technical Stuff 9 11th May 2016 13:41
What is the Difference Between a Two Stroke and Four Stroke Engine? WILDTHING Technical Stuff 3 25th January 2007 08:46
2 stroke ... 4 stroke ......6 STROKE ! pepper Technical Stuff 3 10th March 2005 00:58
