Old 12th November 2015, 21:06   #16
Tanmay K's Avatar
Thanked: 182 Times
Default Re: Honda City VTEC issues
Originally Posted by vinaygurudutt View Post
I have a 2008 honda city ZX Vtec, done 70000 kms. Serviced at 65000 and Clutch not yet replaced. The car has been revving up on its own since this morning. The car revs upto 3000 rpm without accelerator input. The car was pressure washed on Sunday and refilled at the usual petrol station, it ran fine on Monday when it was last driven.
Please advice on what might have gone wrong.
This could be a problem with the throttle position sensor. Do the rpms stay constant at 3000 at idle?
Tanmay K is offline   Reply With Quote
Old 12th November 2015, 21:09   #17
vinaygurudutt's Avatar
Thanks Tanmay,
The rpm fluctuates between idle and 3000 rpm (even in neutral).Clutch operation is normal.
What is the solution and how much should it cost ?
vinaygurudutt is offline   Reply With Quote
Old 13th November 2015, 09:44   #18
Tanmay K's Avatar
Thanked: 182 Times
Default Honda City VTEC issues
Thanks Tanmay,
You can get it checked with a multimeter. Hopefully all it may need is some adjustment. The fact that the rpm varies suggests a fault rather than an adjustment problem but hopefully I'm wrong. I'm not exactly sure of the price, the tp sensor often comes as a part of the throttle body assembly and isn't exactly cheap. If you do indeed need a replacement, try to shop around for the sensor alone and it might be cheaper that way.
Also, there's a wealth of information on tp sensors on team bhp itself. Browsing through some of these old threads might help.
Old 13th November 2015, 11:56   #19
Catalyst_delhi's Avatar
Thanked: 149 Times
Your IACV or Idle control valve could be stuck open due to water ingress to the IACV socket or carbon buildup . If this is ok then look at the throttle sensor as well.
Catalyst_delhi is offline   (1) Thanks Reply With Quote
Old 13th November 2015, 12:37   #20
dhanushs's Avatar
Thanked: 4,507 Times
+1.
I'd also recommend cleaning the Throttle Body and the MAP/MAF sensor.
Old 13th November 2015, 16:47   #21
Thank you for your valuable suggestions.
Heard from the SA at Magnum honda, yeshwantpur . The throttle vacuum pipe was punctured (suspected intrusion by rats) and thus the rpm fluctuations.
It is temporarily fixed until and a new part has been ordered .
Honda issues recall for faulty power window switch on 2nd-Gen City Achyuth Vaibhav The Indian Car Scene 13 3rd July 2013 09:46
