View Poll Results: petrol or diesel for performance ?(read post before vote)
Petrol 126 68.85%
Diesel 57 31.15%
Voters: 183. You may not vote on this poll
Old 3rd January 2011, 12:53   #91
anilisanil's Avatar
Thanked: 288 Times
Default Re: Petrol or Diesel for performance?
Originally Posted by alpha1 View Post
It does not.
Let say you are doing 40 kmph at 3rd gear. at 2000 RPM.
In diesel car - if you need to race to 120kmph you will need to increase the engine RPM to 2000 x 120/40=6000 RPM.
Sadly there are no diesel engines that can rev that high.
So you will shift to higher gear.
On my petrol car I can go upto 140, without changing the gear, because my petrol engine can rev till 7000 RPM.
And ground speed is directly related to engine speed and gearing ratio.
What else can it depend on?
Thanks mate, some how I inadvertantly missed this, I just assumed things for lower speeds!! Thanks for clarifying that technically!!
Though at 3rd gear and 2000 rpm a diesel would be doing more than 40 kmph, I got the gist
anilisanil is offline   Reply With Quote
Old 3rd January 2011, 13:41   #92
oxyzen's Avatar
Thanked: 268 Times
If we consider the current Diesel vs Petrol comparison in India.
Swift Diesel = Swift petrol
Ritz Diesel = Ritz Petrol
Polo Diesel < Polo Petrol
Micra Diesel >> Micra Petrol
Figo Diesel >> Figo Petrol
Punto Diesel = Punto 1.4 >> Punto 1.2
I20 Diesel >> I20 Petrol
Fiesta Diesel << Fiesta Petrol
Verna Diesel >> Verna Petrol
Linea Diesel > Linea Petrol
Optra Diesel >> Optra Petrol
Vento Diesel >> Vento Petrol
Corolla D <<< Corolla Petrol
Leave out turbo petrols and:-
So it is 7 for diesel and 3 for petrol. Thats a white wash.
I too voted for petrol be cause nothing comes close to the joy of revving it to high RPM but India's Car scenario states otherwise.
You are right theoritically but it does not work that way. Petrol and diesel have different gear ratios.
In a petrol you can do 40 kmph at 3rd gear. at 2000 RPM.
But in diesel it will be somewhere around 45-50 kmph at 2000 RPM.
Diesel already have the advantage of torque so they can afford to use higher gearing.
oxyzen is offline   Reply With Quote
Old 3rd January 2011, 14:39   #93
anilisanil's Avatar
Thanked: 288 Times
If you are taking about one car yes, if you are comparing different cars, the ground speed is dependent on engine speed, tire size, gear ratio and final drive ratio.
Since gear ratios differe significantly for diesel and petrol we cannot compare with RPMs directly.
However you are right, one can reach higher speeds in lesser gear for a Petrol engine and for most this is fun and exhilirating.
The question I asked was for similar displacement engines, in most cases where diesel scored above petrol the diesel has a higher cc!!
I agree with you completely, but as I said may be he was just intending to give an example, petrols are fun for revving up (for many) however, I like my engine the diesel way, lots of torque!!!
Old 3rd January 2011, 16:19   #94
alpha1's Avatar
Thanked: 1,035 Times
^ Yes, my intent was to illustrate in simple terms that in same gear you can have a large speed range.
Also higher revs sounds/feel more "racy" ... aint it?
Old 24th May 2011, 13:55   #95
volkman10's Avatar
Thanked: 19,868 Times
See attached document on the future (2015)trends in diesel engines( page 1)
  • cars could exceed 5.2 l/100km
  • reduced emissions
  • quiet and effective combustion
  • improved fuel economy
  • could improve fuel economy upto 43% compared to comaprable petrol engines
  • lower operating cost
Cheers!
volkman10 is offline   Reply With Quote
Old 17th August 2012, 20:26   #96
udiboy's Avatar
Thanked: 7 Times
It does not.
isnt the calculation based on the assumption of linearity, which we are pretty sure is never the case, the torque/power delivery is not a straight line but a curve!!!
udiboy is offline   Reply With Quote
Old 20th August 2012, 21:10   #97
alpha1's Avatar
It was just a "back of the envelope" calculation with simplifying assumptions.
But what I wrote is visible and perceptible also to a large extent.
Diesel:Petrol Car Sales Ratio. Major Shift in favour of Petrol Cars! RSR The Indian Car Scene 70 26th February 2017 11:46
Optra - Petrol 1.6 v/s diesel 2.0 EDIT : Now booked Magnum Diesel manaa45 Sedans 33 13th June 2008 17:16
76mm Honda performance pistons, baleno performance cam & NOS kit for sale. mclaren1885 Shifting gears 6 16th September 2007 14:02
ICE performance differs in petrol or diesel vehicles? panky12345 In-Car Entertainment 10 24th May 2006 15:55
