Old 15th June 2010, 10:15   #16
sgiitk's Avatar
Thanked: 3,883 Times
Originally Posted by shantanumishra View Post
Replaced Engine oil with Chevron Havoline Synthetic Engine Oil 4L for INR 1500
Sorry I was busy at that time and did not look at the thread. Rs.1,500 will NOT get you 4L of a full synth. more like 4,000. Must be a semi-synth. No problems here, just pointing it out
I never go to the A$$ for thinks like exhausts, wiper blades, brake pads, windscreen (if you are unlucky to break it), etc. They are far cheaper outside (at least 2x). Hoses, just check that what you get is OE replacement since other hoses may not last long.
Old 15th June 2010, 10:17   #17
sgiitk's Avatar
Hydraulic tappets should not misbehave. The fact that the fix worked for some time, indicates the correct area for the problem. Get the hydraulic oil checked/changed.
Old 15th June 2010, 15:58   #18
torque4u's Avatar
Thanked: 41 Times
Spoke to them they are saying there is no hydraulic oil, engine oil works for tappets.
torque4u is offline   Reply With Quote
2013 Hyundai Verna Fluidic gets minor updates. And some omissions JayPrashanth The Indian Car Scene 169 25th October 2014 21:43
Stalling/Stopping issues with Accent Viva CRDi mobike008 Technical Stuff 12 19th April 2008 12:21
accent FE issues jesal Technical Stuff 14 27th September 2007 15:09
