Old 7th April 2010, 15:54   #31
sgiitk's Avatar
Thanked: 3,864 Times
Infractions: 0/1 (4)
Originally Posted by smashnerd View Post
Can the rear drum brakes on cars be replaced easily with discs?
Yes and no. Let me explain
Yes: Many D segment and higher cars have all discs, (e.g. Altis, civic ..., even the old City VTeC).
No: The problem is that more effort is required to get a decent hand brake, as the drums have an self clamping action. Some cars even have inboard drums for the hand brake only.
Old 13th June 2013, 21:51   #32
crazyfordriving's Avatar
Thanked: 20 Times
Default Re: Disc brakes - A small query.
[*]On the sidewalls of the pads from Pune, I could read APACHE printed (does this mean that the pads were designed exclusively for TVS Apache's Disc brake system??)
No, it cannot be of TVS Apache as the disc size itself is different (front 270mm and back 200mm petal shaped), the positioning of clamping holes are different for cars and bikes. In this case may be the quality of material used is different.
crazyfordriving is offline   Reply With Quote
Old 14th June 2013, 23:34   #33
Ricci's Avatar
Thanked: 993 Times
Not entirely convincing an argument. Cars too have similar diameter discs up front for one. Two, the pads need not match the exact shape of the disc area in contact. Some units of late on high end bikes use square/rectangular pads per piston rather than single pad for each bank of pistons , regardless of disc diameter , though the usual application means the ballpark disc sizes are not much different ( 300-320mm for most SBKs ).
Ricci is offline   (1) Thanks Reply With Quote
Old 15th June 2013, 00:47   #34
Viju's Avatar
Thanked: 1,688 Times
[*]The design, thickness was absolutely the same including the engraved TVS -Girling mark.[*]I somehow found the materials were different. The set from Pune looked almost black while the MGP looked dark grey.[*]On the sidewalls of the pads from Pune, I could read APACHE printed (does this mean that the pads were designed exclusively for TVS Apache's Disc brake system??)Once replaced, the difference was IMMEDIATE. I got back the bite, smoothness as well as the play in the braking system.
Hence, for all those who replace their pads, please ensure that they are original and intended for your car make/model.
Hello paragsachania
Just to clear this up. MSIL has multiple vendors for a component for most of their models (except very low volume ones like SX4).
TVS Girling, as you correctly mentioned is Brakes India. 'Apache' written on your new set of pads has nothing to do with the TVS motorcycle though.
Apache is a grade of pads from the other vendor - previously KBX, then Bosch India and now FBIL (Foundation Brakes India Limited), Pune. Hope this clarifies.
Viju is offline   Reply With Quote
Old 17th July 2016, 18:47   #35
Ponbaarathi's Avatar
Thanked: 111 Times
Why do disc brakes in bikes have holes whereas those in cars dont have?
Ponbaarathi is offline   Reply With Quote
Old 17th July 2016, 19:16   #36
sudev's Avatar
Thanked: 2,502 Times
Higher end or performance disk brakes also have holes. Helps is fast dissipation of heat resulting in better brake performance.
There are also grooves to throw out water so that friction is maintained at highest levels.
See https://goo.gl/images/5Gq2al
sudev is offline   Reply With Quote
Bikes - Anti Lock Braking system on Disc Brakes mail4ajo Motorbikes 10 2nd March 2015 11:40
Drum brakes to Disc gdhiraj Modifications & Accessories 54 18th March 2013 12:19
Squeaky disc brakes on 1.8TPI? nanu28 Technical Stuff 8 3rd February 2007 00:14
Disc Brakes for Rear Wheel ~ H O N D A ~ Modifications & Accessories 39 24th June 2006 09:50
Disc Brakes - can someone xplain them to me? Shan2nu Technical Stuff 17 9th March 2006 00:08
