Old 26th March 2010, 07:11   #1
Thanked: 456 Times
Default Immobilizer - A dumb question
Hi Friends - The dealer told me that my i10 Magna Automatic has factory fitted immobilizer. How do I verify the same? Also, do insurance company give any discounts if immobilizer is present in the car?
Simhi is offline   Reply With Quote
Old 26th March 2010, 09:43   #2
ghodlur's Avatar
Thanked: 2,431 Times
Cool
@ simhi
You can confirm by checking on the dashboard where you can see a red light blinking which means that the immobilizer is on.
Of course you can get the discounts from Insurance company if Hyundai guys confirm that the anti theft device i.e the immobilizer is ARAI certified. I got a discount for my Ford Fiesta from ICICI Lombard.
ghodlur is offline   Reply With Quote
Old 26th March 2010, 09:52   #3
lalitk25's Avatar
I have another doubt does iCat in maruti car has the same function as Immobilizer?
lalitk25 is offline   Reply With Quote
Old 26th March 2010, 09:53   #4
ImmortalZ's Avatar
Thanked: 312 Times
A red light blinking can be anything.
Most cars with immobilizers have a light on the meters which looks like a key. This lights up for a moment when you turn on the ignition and stays lit when the immobilizer is tripped by a fake key.
Old 26th March 2010, 10:13   #5
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
One simple way to check.
  • Unlock your car. This should disable your immobilzer. Get inside the car and close all the doors.
  • Lock the car while you are inside the car using your remote lock (I hope you have that on the key). This should arm the immobilzer.
  • Try to start the car without unlocking the car. This should activate the alarm in your car and you should not be able to start your car.
  • Check your manual. There should be some visual indication to show that somebody had tried to start the car. (They generally indicate what type of intrusion was there - someone trying to open the door, someone trying to start the car, triggering of the shock sensor etc.)
-Biju
pjbiju is offline   Reply With Quote
Old 26th March 2010, 18:52   #6
Thanked: 456 Times
Thanks friends. I checked the instrument cluster and noticed that the immobilizer in Hyundai i10 Magna AT is displayed with a car and key symbol. This lights up when we insert the key and goes off once we start the vehicle.
Old 27th March 2010, 12:07   #7
knp
Thanked: 18 Times
Does i10 kappa sportz has immobilizer?
knp is offline   Reply With Quote
Old 27th March 2010, 12:18   #8
.anshuman's Avatar
Thanked: 9,159 Times
iCATS is also an immobiliser, it works exactly the same way.
Old 27th March 2010, 12:27   #9
NutsNBolts's Avatar
Thanked: 32 Times
-Biju
The code for immobilizer is embedded into the key. When the key is inserted, the ECU verifies the code and removes inhibitor/immobilizer. So with your key, you can start the car even when you lock the car from inside. Immobilzer is related to engine and car lock is a separate safety device.
NutsNBolts is offline   Reply With Quote
Old 27th March 2010, 17:52   #10
suzuki san's Avatar
Thanked: 346 Times
Hi Simhi,
Yes. Insurance companies do give a discount if the vehicle is fitted with an immobilizer or as they call it "An anti theft device".
I have just got a discount for the same.
SS
suzuki san is offline   Reply With Quote
Old 27th March 2010, 19:04   #11
NetfreakBombay's Avatar
Thanked: 402 Times
Get a duplicate key made from road-side keymakers.
This key should open the door. But it would not be able to start the engine.
Old 27th March 2010, 22:09   #12
Thanked: 456 Times
Thanks friends for all the inputs.
@knp: If i10 Magna has immobilizer, I guess Sportz Kappa (higher variant) should also have it.
Old 27th March 2010, 23:08   #13
GSMINC's Avatar
Thanked: 114 Times
Yes, agree with you, I had my SWIFT keys made in silver & I could open doors, but not start the engine
Originally Posted by suzuki san View Post
Hi Simhi,
SS
Generally, They tend to ignore this discount portion, just insist on it they will give in.
GSMINC is offline   Reply With Quote
Old 28th March 2010, 00:49   #14
.anshuman's Avatar
Even the immobiliser is not foolproof, A friend's Swift VDi was stolen last month. The car was left unattended for just 15 minutes.
Old 26th May 2010, 18:25   #15
lalitk25's Avatar
Seems Interesting.... I would say either thief had a duplicate key and after opening they towed it away otherwise I am ready to listen what could be another way of stealing a car with immobilizer fitted in?
Because SK motors in chandigarh told me not to fit a car lock as swft vdi is equipped with iCat.
Matiz : A dumb question on "reserve fuel lamp" kshastry Technical Stuff 25 15th January 2008 13:33
Dumb question about sensors....but i gotta know rohan_fonseca Technical Stuff 6 19th April 2007 03:38
Another dumb question from a noob!! archat68 In-Car Entertainment 3 3rd January 2007 06:27
Car Launches in India: Why they invite dumb celebs Dippy The Indian Car Scene 39 20th December 2005 13:04
A dumb question milindbajekal The International Automotive Scene 8 10th September 2004 14:08
