Closed Thread
Old 27th March 2010, 16:23   #1
Archish's Avatar
Thanked: 87 Times
Default Emergency... Innova Overheating!!! Parents Stranded near Krishnagiri.
Mod Note : Please continue the discussion in our Engine Overheating Article (What to do if your Engine Overheats on the road). Thanks
My dad and mom are on Chennai Bengaluru NH right now. Near Krishnagiri. They have taken our Innova. My dad just called to say that the cars temp. meter has risen to 'H' fully and the A/c compressor has cut off. He says he sees some kinda pink powder behind the Radiator. And also there is no Coolant.
I just got the car serviced with Raghav @ 'Ignite' yesterday. He had changed the clutch assembly. And also general service. Pls Help me out.
What can I do? This is the first time that this is happening to this car.
Archish is offline
Old 27th March 2010, 16:32   #2
Thanked: 147 Times
Tell them to stop driving as soon as they find a decent place to stop. Looks like a Fan Failure or something. Maybe a thermostat Failure.
Cyrus43 is offline
Old 27th March 2010, 16:35   #3
Archish's Avatar
Thanked: 87 Times
They have already stopped driving. Fan is working. That is the first thing that i asked him to check. Fans is running.
Archish is offline
Old 27th March 2010, 16:43   #4
bejoy's Avatar
Thanked: 409 Times
Ask your parents not to panic. Looks like a coolant leak. Allow the engine to cool down completely and fill normal water in the coolant tank. Continue driving till the next town and get help from a garage. Keep an eye on the temp gauge and stop in between to check the water level, refill as necessary..
bejoy is offline
Old 27th March 2010, 16:45   #5
discoverwild's Avatar
Thanked: 950 Times
Ask your father to check the service booklet for a Krishnagiri service station. I hope there is one. They could help with the tow and also if nothing serious (like a burst tube) provide a replacement immediately.
discoverwild is offline
Old 27th March 2010, 16:46   #6
mjothi's Avatar
Thanked: 216 Times
Best is to call Toyota service and inform them. They should have some checklist to narrow down.
Then based on the intensity of the issue they can drive down (check if you can fill it with coolant or distilled water.)
Also, there are numerous petrol bunks along the route from krishnagiri to bangy, so check with some nearby bunks to see of they have coolant available.
mjothi is offline
Old 27th March 2010, 16:47   #7
sdp1975's Avatar
Thanked: 920 Times
You said there is no coolant , has it leaked out ? Does toyota have road side assistance service ?
sdp1975 is offline
Old 27th March 2010, 16:56   #8
Archish's Avatar
Thanked: 87 Times
They have filled it up with water... They are not exactly on the highway, they are moving from thirupatur to krishnagiri, its a State Highway.
There is no toyota at Krishnagiri.
There is Lanson Toyota at Vellore.
They have filled it up with water. The temperature is down to half now. They are moving again. I have asked them to return to chennai. Also to check the water level every 50 or 60 kms. If needed, i have asked them to go into Lanson in Vellore.
Archish is offline
Old 27th March 2010, 16:56   #9
iamback's Avatar
Try spraying some water on radiator and on the engine.
iamback is offline
Old 27th March 2010, 17:03   #10
Archish's Avatar
Thanked: 87 Times
is this is a good idea?
Archish is offline
Old 27th March 2010, 17:03   #11
vinaydas's Avatar
Thanked: 85 Times
91-416-2249451-52
this is the Number for Lanson Toyota Vellore.
either this or you will have to try Nandi toyota hosur road.
Yes they have on spot repair facilities.
vinaydas is offline
Old 27th March 2010, 17:06   #12
lloydofcochin's Avatar
Thanked: 180 Times
That helps. I suspect a burst pipe or something. Ask them to get a 3-4 2ltr bottles of water and fill up the radiator if the temp gauge rises again.
lloydofcochin is offline
Old 27th March 2010, 17:15   #13
Archish's Avatar
Thanked: 87 Times
They justed filed up the radiator with coolant. They have driven 20 kms since. And there is no rise in Temperature.
What is the pink powder? Dried up coolant?
Archish is offline
Old 27th March 2010, 17:17   #14
Thad E Ginathom's Avatar
Thanked: 7,226 Times
If they can't get a proper engineer there to deal with the situation...
1. Let the engine cool down. Give it several hours, I guess.
2. Fill up the coolant with plain water.
3. Drive home, keeping an eye on the temperature guage and coolant levels.
4. Get service centre to flush and refill with proper water/additive mixture.
On no account remove the radiator cap while the engine is still hot.
I learnt this the hard way. I was lucky: the gush of steam and boiling water missed me. If I had been leaning over it, I wouldn't be nearly so good looking as I am today.
<Sorry: crossposted with lots of other good advice>
Thad E Ginathom is offline
Old 27th March 2010, 17:36   #15
Archish's Avatar
Thanked: 87 Times
They are at krishnagiri now. Have driven about 40 kms. of which 20 was with A/c. The temperature has settled to normal. They jus checked the coolant water level. It has not dropped. They are anyways returning to Chennai now.
Again, what could that pink powder be? Dried up coolant?
Archish is offline
Closed Thread
Kalkunte, Chikka Tirupathi, and Krishnagiri Dam! agag Travelogues 8 24th April 2012 06:45
ThimarayaSwami Betta near Nandhi hills & Sivappana Betta Near Sangam hisunil 4x4 Excursions 6 8th October 2010 08:56
Hotel accomodation between Krishnagiri and Coimbatore Jorge Route / Travel Queries 22 18th January 2008 17:03
THOPPUR GHAT to KRISHNAGIRI kb100 Route / Travel Queries 8 11th October 2006 14:20
Bangalore Team-BHP drive to Krishnagiri on July 17th 2005 Samurai The Team-BHP Meet Section 50 27th July 2005 19:27
