Old 31st March 2010, 00:08   #1
Thanked: 24 Times
Default Help needed, underbody damage in OHC
All,
Today was a unlucky day for my OHC 1.5, didn't notice a hump and went over it at a good speed - looks like this has caused some damage in the underbody. Since it was late at night, I couldn't stop and examine the damage. Came home and took a couple of photos that shows the damage.
You can see that there is some kind of a leak, I am not a expert to understand the extent of the damage - can some one help out?
I want to know a couple of things.
1) It looks like the oil sump has got hit, is that a valid assumption? I checked the lights in the dashboard, there was no indication of low oil or anything.
2) The service station is atleast 10Kms from my home, is it ok to drive the car in this state? The car is running well except for some different sound.
Thanks in advance.
partha379 is offline   Reply With Quote
Old 31st March 2010, 01:10   #2
ph03n!x's Avatar
Thanked: 120 Times
Even if you doubt damage to the oil sump, it is safe to NOT start the car, and have a competent mechanic check the car at home to assess the damage. If a parked car is leaking oil a bit, it will leak a lot more when started.
ph03n!x is offline   Reply With Quote
Old 31st March 2010, 09:19   #3
Psycho's Avatar
Thanked: 95 Times
Well the damage is not that bad, you should be able to drive it down to the service station for a check, just keep an eye out for the oil light.
Old 31st March 2010, 09:28   #4
Thanked: 24 Times
To add more info, the liquid you seen on the floor in the first pic is actually the water dripping because of the AC unit.
I am interested in what the tank holds, am I right in assuming that it is the oil sump. I checked again today morning, the oil light didn't glow - but to be safe I am not taking it out at this moment.
Old 31st March 2010, 09:54   #5
Jaggu's Avatar
Thanked: 8,694 Times
I dont think you have damaged the sump. Just clean it with some good soap water and observe if its dripping, either its the oil that sprayed after oil service or the sump gasket is leaking a lil which is giving the wet look. The drops you see behind seems to be AC condensation water coming from inside.
Old 31st March 2010, 10:09   #6
aargee's Avatar
Thanked: 2,143 Times
@partha - When did you take the pics? Was it immediately after parking the car? Then there're high chances of water dripping due to A/C. BTW - were you driving with A/C ON or OFF?
Just update us in the morning about the dripping that you see on the floor & if possible update us with some more new pictures.
@Jaggu - I was about to tell the same thing, you spoke my mind.
Old 31st March 2010, 11:51   #7
sushrutha's Avatar
Thanked: 325 Times
Did you get your car checked from a Mechanic ??
I'm interested to know as what that different sound is ???
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
Help needed in attending the problems in my 2001 OHC vtec msk_kapoor Technical Stuff 7 8th December 2009 10:34
Help! Pointers needed to inspect an OHC 1.5 Vtec before purchase amit_mechengg Sedans 18 5th October 2009 19:05
santro front underbody damage due mumbai roads gigy Technical Stuff 4 27th July 2006 14:16
