Thread Tools
Old 4th October 2005, 16:48   #1 (permalink)
Default tata safari suspension issue?
Hi guys,
I went for a spin to mercara from bangalore over the weekend with my dog and we enjoyed the trip. But i had an observation that i wanted to verify with you guys while i was driving my vehicle over the fantastically pot-holed roads enroute!
Every time i tried to slow myself down, i felt the vehicle shift to the left a little bit. This only used to happen over some really lumpy roads and only when i tended to brake a little suddenly. I thought of 3 different reasons for this behaviour:
1. the shock absorbers are too stiff and the vehicle does not yield gracefully and hence it slides sideways
2. the tyres (bridgestone dueller 255R15s) are too hard and dont sink down into the obstructions
3. maybe improper driving with a little much clutch while braking causing a little freewheeling of the vehicle combined with an alignment issue
Either way, i was a little puzzled with the behaviour. It did not bother me and i still did mysore-mercara in 2 hours 20 mins which was reasonably quick but it made me a little more careful on the curves and the really bad sections of the road. If you guys think that this is an issue only with safaris or the style of driving then let me know.
thanks for your help
idrive is offline   Reply With Quote
Old 4th October 2005, 17:29   #2 (permalink)
BUSA's Avatar
This is surely an issue with the alignement of the tyres! The wheels are not popularly aligned so will tend to go left or right on braking depending on current toe, caster and camber settings!
__________________
Got Bhp? Team-Bhp.com
Old 4th October 2005, 17:57   #3 (permalink)
SUV
SUV's Avatar
The Safari does not have a Camber adjustment, Only Toe which can be adjusted.
The Camber can be adjusted by inserting Shim's between the Top Plate housing.
Might be the 255's have had some affect on the Camber as well.
From My Experience The Bridgestones dont perform on a Safari and tend to have these issues. I wonder why though ... could never figure out ... .i had them i my earlier Safari and did have them in the current one (Read New) as well ( now am running Yokohama Geolander AT+II :-) handles like a dream).
SUV is offline   Reply With Quote
Old 4th October 2005, 18:17   #4 (permalink)
ananthkamath's Avatar
Originally Posted by SUV
The Safari does not have a Camber adjustment....
First you say it can't, then you say it can....
ananthkamath is offline   Reply With Quote
Old 4th October 2005, 19:13   #5 (permalink)
Stratos's Avatar
I remember hearing / reading somewhere that the New Safari has a problem of getting sideways (well not in the sporty means ) under little exploitation. I guess some magzine posted it in their Safari DICOR test coverage.
Stratos is online now   Reply With Quote
Old 4th October 2005, 19:16   #6 (permalink)
adya33's Avatar
that explains their advertisement
adya33 is offline   Reply With Quote
Old 4th October 2005, 19:21   #7 (permalink)
Its to do with the brakes - Autocarindia pointed this out in their testdrive. Probably a brake bias issue, but scary nevertheless.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 4th October 2005, 19:33   #8 (permalink)
veyron1's Avatar
yup, i think so too. in fact, my safari used to have the same problem for a few months, and then after i checked out the car myself, i found that the LSPV (load-sensing proportioning valve) at the rear wasn't working properly, due to which the rear braked prematurely (never locked-up, though)....try checking it out; change it, if necessary....
__________________
DAD
veyron1 is offline   Reply With Quote
Old 5th October 2005, 00:51   #9 (permalink)
Steeroid's Avatar
Hey when I mentioned the overheating rear brakes (while going downhill) issue to the service manager, he mentioned this valve - I didnt quite get what he said because my mind was on my ticket for the next days flight, but he did say that this valve should take care of any such issue...
By the way, Ive never had this sideways movement under braking that Autocar mentioned. Its always stopped in a straight line - even on some very drenched and slippery roads, though ABS should've been standard.
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 5th October 2005, 10:42   #10 (permalink)
This is does not seem like a brake issue. I did speak at length to the service guys and the answer that i came away with is that the EBD + ABS + LSD is supposed to correct all of this. Somehow i cannot believe that answer so easily because the earlier vehicle i used to have (2001 EXi) never used to do this. Anyhow i think Tata does not stability control which keeps the vehicle in the right angle while moving but they definitely do have EBD/ABS in the higher end dicor. If the functionality works then you guys should not be seeing this problem in the newer vehicles. I will keep you guys posted if i come up with anything new. thanks!
Old 5th October 2005, 12:16   #11 (permalink)
Steeroid's Avatar
Funny part is that the Tata Service engineers wont even listen to your request if you ask them to put the ABS/EBD on the non-ABS/EBD models. I told them cost is NOT a consideration, yet they wont even think along those lines.
__________________
Steer
Old 6th October 2005, 01:34   #12 (permalink)
veyron1's Avatar
what it actually does is, it reduces the pressure of the hydraulic fluid going to the rear wheel cylinders as it senses a decrease in load, and vice versa. basically, it should prevent the wheels from locking up under no-load or full-load situations, but if it's faulty, it doesn't regulate the pressure, resulting in skittish braking, differentiated handling, etc. & also heated drums, as the shoes are always in contact with the inner surface....
LSD's are O.E on all safari 4x4's, and they do not affect the handling or braking characteristics of the SUV.... the LSD only comes into play when either of your rear wheels are spinning out of control, since only the rear has LSD. the front has a live axle, with sun and star type geared differential (normal ones found in sumo's or scorpio's rear)...
but even the DICOR vx that i drove, had not-so-effective brakes and handling; damn, tata shouldn't have touched the suspension and steering dynamics- it was so good before...now they are gonna have to improve upon the DICOR, which would disappoint the initial customers....
he..he...yeah, they hesitate to do any sort of "upgrade" mods, because of these 2 reasons (i think).. a) they do not have the expertise, and b) they do not do anything that tries to foul the warranty...
__________________
DAD
Thread Tools
Issue with tata/safari, fortune motors, powai csgup1 The Indian Car Scene!! 4 4th October 2008 08:40
Suspension setup Safari Dicor 3ltr v/s 2.2 ltr PAVAN KADAM Technical Stuff 13 13th May 2008 13:49
It's Official: Mid-Day report on Civic Suspension issue amit The Indian Car Scene!! 40 4th May 2008 09:04
Safari EX suspension or what? ikshayar Technical Stuff 7 11th August 2007 02:20
Safari DICOR LX starting issue, and some more tsk1979 Technical Stuff 13 27th March 2007 11:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
