Closed Thread
Old 1st April 2010, 19:09   #1
Sudan_NFS's Avatar
Thanked: 13 Times
Default Advice & tips :Santro xing not going to be moved for 3 months
I need some advice on my santro which is going to be left standing for 3 months from now.I did a regular 6 month services just a week back.
I have a great fear in removing the batteries because when it is fitted again and if the person doesn't fit's it properly then it would be great issue.
Looking for a much need advice so that nothing goes wrong.
Sudan_NFS is offline
Old 1st April 2010, 20:48   #2
aargee's Avatar
Thanked: 2,142 Times
Sudan - No worries, get the battery checked at the nearest authorized battery dealer & top up if required; remove the battery & most importantly, mount it on a wooden stand or stool.
Fixing the battery back is a child's play & it can be done easily; let me know if you want a DIY & I can post it for you.
I'm did the same when I was away for 3 months; when I came back & connected the battery, the car started just fine.
Edit - Provide a free pick up & drop & tip the guy at the battery dealer, he'll most probably be able to do it.
aargee is offline
Old 1st April 2010, 20:55   #3
samsag12's Avatar
Thanked: 206 Times
+1 to what aargee said. Just remove the battery from the car store it in a dry place. If you want then you can spray some type of deterrent which keeps the rats and other strangers away from your car.
samsag12 is offline
Old 1st April 2010, 21:20   #4
sachinj12's Avatar
Thanked: 162 Times
I might be sound a bit stupid, what about the tyres? How do you protect them when not used for long periods?
sachinj12 is offline
Old 1st April 2010, 21:38   #5
Hashim's Avatar
Thanked: 32 Times
1. Disconnect the battery, just take out the Negative Terminal (-) Black wire from battery. When you come after 3 months, just connect it back. Before this get the battery water level topped and battery fully charged.
2. Unscrew all the spark plugs and put 2 - 3 drops of engine oil in each hole and put the spark plugs back.
3. Put the car on jack and place wooden blocks under the chassis such that when you remove the jack, the wheels are slightly above the ground and do not touch it.
4. Clean the car both inside and outside and see if there is no edible stuff inside your car which can attract mice etc. Interior should be dry and not damp at all otherwise it will develop fungus.
Hashim is offline
Old 1st April 2010, 21:40   #6
greenhorn's Avatar
Thanked: 1,516 Times
http://www.team-bhp.com/forum/techni...dos-donts.html (Long-term Parking : Do's and Don'ts)
greenhorn is offline
Old 1st April 2010, 22:14   #7
Eddy's Avatar
Thanked: 5,067 Times
Thanks Greenie !
Please continue in the thread mentioned above.
Eddy is online now
Closed Thread
New Santro Xing vs old Santro Xing (eRLX) DCEite The Indian Car Scene 3 21st May 2012 21:48
Disc plates changed 4 times in 5 months(Steering wobbling)- Santro Xing. akshay_b Technical Stuff 37 1st October 2011 22:15
Planning going to NewZealand for 6 months, advice/help required. yzfrj Shifting gears 7 23rd March 2009 16:01
New Santro Xing/ Need Alloy & Audio tips! sumanvr Modifications & Accessories 1 20th October 2006 10:07
