Old 3rd April 2010, 11:24   #1
Default Gear lever console getting heated up in my Safari TCIC
Hello everybody, this is my first post on Team BHP, I recently got a 2000 model Safari TCIC 4x4 and am very excited about it. I have read so may threads about ownership and feedback and travelogues and always wanted a Safari, 4x4 ofcourse couldent afford a new one, so settled for a very good condition. I shall post my experience and pictures soon under the appropriate section soon, but first things first, driving on the beach, and even on highways, I have noticed the plastic console where the gear lever is mounted in the cabin gets hot. Is this normal? or is there something wrong? Need help
Senz is offline   Reply With Quote
Old 3rd April 2010, 19:56   #2
Thanked: 244 Times
Hot Air from the engine is leaking inside, you need to check from the engine side the the underbelly. Plug any holes and open areas.
Old 4th April 2010, 15:58   #3
Thank You Dadu, have given the truck to the mechanic, to check, let me see, I was worried if it has anything to do with the excessive use of the 4x4, since i did spend a lot of time with the car on the beach on both low and high mode.
Rumour: Sail sedan & hatchback recall soon (gear lever comes off!) Insouciant Technical Stuff 3 12th April 2014 17:16
Gear lever play in OHC VTEC. vishnuvijay Technical Stuff 15 4th August 2011 12:25
Rx135 4 speed -bore gets heated prsnck Motorbikes 15 14th June 2010 16:39
Gear-shift lever vibrations girishab Technical Stuff 12 10th June 2008 13:48
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 17:42
