Old 5th October 2005, 14:35   #1
shazikon's Avatar
Thanked: 19 Times
Default Hard clutch
hi,
The clutch pedal on my ikon 1.6 is hard when i press it. Release is not smooth either.Some times the car jerks while comming out of first gear. My car has done 44K kms. what could be the problem, do i need to change the clutch liner and cable ??
thanks,
shaz
shazikon is offline   Reply With Quote
Old 5th October 2005, 16:11   #2
satan_crazy's Avatar
hi, try changing the clutch cable
s
satan_crazy is offline   Reply With Quote
Old 5th October 2005, 22:48   #3
sparco's Avatar
Originally Posted by shazikon
hi,
thanks,
shaz
dude 44k i think its time to change the cluch & pressure plate wich will cost you around 6-8k because ikons got dual clutch or else check the clutch release bearing....had the same problem in my ikon...
sparco is offline   Reply With Quote
Old 6th October 2005, 11:29   #4
shazikon's Avatar
Thanked: 19 Times
thanks guys..for the replies..I got this problem checked by cauvery ford in Bangalore and they said they have done a clutch servicing..But i really doubt if they have done any thing..
A little out of topic.. are there any good car service centres/ mechanics in Bangalore who can do a good job of servicing my car, clearly identify problems and take corrective repairs... i am very very sad at the so called "quality" care provided by cauvery and metro ford in Bangalore ... They need so much pestering by me to get the car serviced properly and repair all the problems i showed by me.
Can you guys in bangalore direct me to some reputed, mechanic/service centre whom i can trust??
thanks,
-Shaz
Old 7th October 2005, 00:15   #5
Thanked: 38 Times
There is one near Ulsoor called Kolimi automibiles, have had a good experience with them in Bangalore.
cheers,
raihan is offline   Reply With Quote
Old 14th October 2005, 10:05   #6
I just test-drove an Indigo TDi last week. The clutch was ROCK hard, and with the frequent gear shifting, the test-drive was hopeless. The dealer claims the clutch is like this in all new Indigos, is this true? Would be grateful if any existing Indigo owners shed some light on this.
Cheers,
ballkey
PS: Does the Gear shift lever always wobble so much in Indigos?
ballkey is offline   Reply With Quote
Old 18th January 2008, 12:02   #7
nura's Avatar
Sorry to revive this old thread but I have a similar problem in my Santro LS 2002. The clutch pedal is hard to push but there is no clutch slipping. Do I need to overhaul the clutch or just replace the cable? The car has done 60K km. In case I need an overhaul, which good brand(s) of clutch plate, pressure plate, clutch release bearing & cable can I buy from the aftermarket? I would like to avoid visiting a HASS.
Thanks in advance.
nura is offline   Reply With Quote
Old 18th January 2008, 12:13   #8
snaronikar's Avatar
Thanked: 23 Times
@ Nura: As it has done 60K kms, my opinion is either change the clutch assy of if the clutch is good do a complete overhauling along with the clutch cable etc. This should solve the problem.
snaronikar is offline   Reply With Quote
Old 27th November 2011, 11:05   #9
libranof1987's Avatar
Thanked: 4,213 Times
Default Re: Hard clutch
Damn! I've to revive this thread.
So, I'm driving my Corsa at 5.30am and all of a sudden, the clutch becomes hard to press. At first, I think I've pressed the wrong pedal (!) but after trying again, it is indeed the clutch going hard. I get home cautiously and sleep over it.
I checked it this morning again and same story - hard clutch. Now, when I engage the reverse gear, the car jerks backward. The other gears don't induce jerking but are still hard to engage.
Time for clutch replacement?
I spoke to a mechanic recommended on T-BHP; he said, it could be something to do with sleave cylinder. Any idea what that is and if that could be the cause?
Clutch replacement at A.S.S. = 12k = almost my new year eve celebration budget. Please give me some good news
libranof1987 is offline   Reply With Quote
Hard clutch in Esteem. GoodGuy Technical Stuff 6 3rd May 2014 08:32
Hard Clutch on the Baleno bruce Technical Stuff 15 6th September 2009 20:48
04' WagonR - Poor FE, Hard clutch and judder DCEite Technical Stuff 12 30th September 2008 10:17
Ford Ikon Flair - Gear Shift & Clutch hard snaronikar Technical Stuff 6 6th October 2007 04:06
Palio and its hard clutch prkothan Technical Stuff 0 13th December 2005 12:04
