Old 10th May 2010, 01:35   #16
nitrous's Avatar
Thanked: 285 Times
Who knows how used these dampers are?
I would strongly suggest you get new ones.
If it were me, I'd pay for SGP. Suzuki is far superior to Maruti's vendors.
Old 24th February 2013, 19:56   #17
Thanked: 27 Times
Default Re: Baleno Shockers leaking oil after 50,000 km
I need to reopen the discussion. I own a 2005 Maruti Baleno which has done 80k + kms. It was driven with utmost care till 2009 and since then it is mostly driven normally by me although at times I tend to take some sharp turns with a bit of speed. At rare occasions I have tried drifting on it too but very rarely.
Now, I feel the suspensions are out as normally on speed breaker or bumps I used to hear a hydraulic compression sound which is absent now and instead a slight thud can be heard.
I showed it to my mechanic who checked them by pushing the car body by hand and said the car is only running on the springs. He recommended getting the shockers replaced instead of getting them repaired. He told me a price of approximately 14k for all four shockers. He said the shockers would be Gabriel, Delphi or Munjal.
I checked with Motocraft Noida and Carnations Noida and they told me price of approx 9k and 8k respectively for one shocker. They also told me that there is no other options other than MGP shockers for Baleno. Also Motorcraft said there was no warranty on the MGP shockers whereas Carnations said 6 months.
I would like to seek help in understanding:
1. Is it possible that the shockers are fine and the problem is something else?
2. Is there an alternative to the MGP shockers for Baleno? If yes, which ones?
3. Are the costings provided above are correct?
Thanks,
Asif
TorquePeedo is offline   Reply With Quote
Leaking front differential oil in my grand vitara 2007 GRV 4x4 Technical 20 28th August 2009 13:07
Underbody hit & now oil is leaking. sriturl Technical Stuff 21 4th July 2008 08:35
