Old 7th April 2010, 19:39   #1
amith.2974's Avatar
Default Rattling sound with baleno
Hey guys, for the past few days, I've been experiencing a significant rattling throughout the car when i begin to move the car in first gear. When i stop at signals and move, i feel the rattle, and it is even more significant when i move the car up a slope at first gear. Any idea what this could be? My car runs on a FFE and run 34000 kms by the way.
amith.2974 is offline   Reply With Quote
Old 7th April 2010, 20:22   #2
WhiteKnight's Avatar
Thanked: 76 Times
Well, you have to do some homework, as there are many possible causes.
1) Could be a problem with the mounting bushes getting hardened, thus causing some resonance.
2) A slightly loose-fit bonnet could cause resonance.
So, please look around
WhiteKnight is offline   Reply With Quote
Old 7th April 2010, 21:33   #3
rjstyles69's Avatar
Thanked: 795 Times
amith any idea where the rattle is originating from, as in the front left or right side, engine bay or eslewhere ?
usually the prime suspect would be the engine mounting bushes. However I wouldn't rule out the exhaust bolts and other mundane stuff.
Old 7th April 2010, 22:15   #4
amith.2974's Avatar
Thanks for the replies guys. Whiteknight, I think i can safely rule out the fact that it is a loose fit bonnet. Hard to say where it originates from, but from my point of view i think it is from the center. Its a pretty significant rattle that can be experienced throughout the car, even if you are sitting at the back, you can very easily feel the rattling. All this only at first gear.
RATTLING sound in car due to audio system... torque.steer In-Car Entertainment 4 9th March 2010 10:14
Rattling at idling - Baleno silver baleno Technical Stuff 8 22nd February 2009 16:11
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Rattling sound? Raps Technical Stuff 4 4th February 2006 10:43
